PROBLEM SOLVED!
Short answer, It was the Hazard Switch.
Long:
Here was my general method.
I'll try make it detailed so it really can help anyone who has a similar issue in future.
1. Indicators stop working
2. blame brother who borrowed car then snapped key off trying to pry gastank cap.. and then who tried to hotwire my car for a few hours so he could drive home.. and never cleaned up after his experiment.
3. make a decision to stop flippantly throwing money into my car and actually start learning about it.
3. come here, see link for online manuals at hmaservice.com
4. incorrectly test my flasher, order a new one, same poor result.
5. return here for some solid advice, thanks again everyone!
6. run a flasher test found at hmaservice and find flasher to actually be working properly.
here is the test, as it's instructed in one of my earlier posts:(IMG:
http://i767.photobucket.com/albums/xx317/stitchymandibles/flasherunittest.jpg)
basically, you need two 21w bulbs to create the correct resistance (ohms) for the flasher unit to do its thing.
also, it's important I suppose you use decent wires, i used wire from an old powersupply for my computer.
i just used some dodgy electrical tape to hold the wires in place.
for these lamps, the sleeves were negative, the nob on the base was positve.
the photo shows the lights blinking about 90 beats a second
apparently, the test is not dangerous to the flasher.
6. downloaded 'Auto Repair for Dummies 1999' (this isn't very helpful for auto-electrics)
7. downloaded 'Electronics for Dummies' which has a great section on multimeter testing and electonic basics.
8. buy a $9 multimeter from jaycar.com.au along with some 10A copper wire and wire cutters.
9. studying the schematics at hmaservice and using multimeter, I work out that power is getting to the hazard switch but not leaving it.
10. the hazard switch is removed, so i test the socket where it connects
11. two terminals on the socket record 12 volts. one terminal all the time, the other only when car is 'ON / START'
12. schematics show that I want the latter of those two, the variable terminal, to get its juice to the flasher.
13. so, I disconnect the battery, then plug a multimeter probe into the B (for Battery) terminal where the flasher normally sits.
this is shown here with the arrow (note, this is a RH driving australian version, but everything should be the same on the compartment relay board.. still, make sure!).
(IMG:
http://i767.photobucket.com/albums/xx317/stitchymandibles/compartmentrelayflasher.jpg)
14. I test each of the terminals in the plug where the hazard swtich goes, and find one that has 'continuance' to the flasher.
15. I find one, so I connect a small piece of 12V 10A wire from that terminal to the 12V 'ON/START' terminal I mentioned... effectively patching the juice across and bypassing the hazard switch.
16. I reconnect battery and flasher, and now the car works fine! (apart from needing a new emergency switch)
I can't believe that was it! I figured that because both hazard and signals didn't work, it had to be something related to them, not actually them..
woulda thought they could operate totally independant but i guess that may take two flashers.
Thanks again for all the suggestions and I hope if you have similar issues on a '95 and need further info, you'll contact mecheers,
tim
