Hi,
I have a 99 tib. and have had a tranny rebuild and a used tranny put in.The first was because the fluid
was replaced by dealer(not hyundia)and they used wrong fluid.The used one worked fine for a couple of
weeks then it stopped going into first and overdrive.I can get in sometimes,warm or not and it will shift
fine.Then I can drive it and it will lose it for no apparent reason.I have also been going about 30 and shut off engine
quickly in N and after it stops chiming (boots up)It will shift fine! Its always the same. if no first gear, no o.d.
It has about 140k on the motor so it has plenty life left!
Ths for your time I have enclosed a pic so you can see why I want to keep it
