 Hyundai-Forums.com > Hyundai Models > Getz Forum
> 1.5td Getz - Turbo - Performance & Shocks Advice Please
CL1V3
post Oct 17 2009, 10:46 PM
Drives: Hyundai Getz
hi all, ive got a 1.5td getz - i want to know how to improve the performance - i have been told about the actuator for the turbo but i do not know weather to crack the bottom nut and wind the rod further IN to the acuator or further OUT can someone point me in the correct direction and how much to turn it by? also will a panel air filter help and if i take the cat out will that help? any advice would be great and or any other things i could do to improve performance - also i have lowered the car 30mm on gmax lowering springs can anyone tell me where to get performance shocks/dampers because i need them as the ride is strange its not hard and not soft the dampers are allowing too much for the springs so id like performance shocks - any help would be much appreciated - Cheers Clive
This post has been edited by CL1V3: Oct 17 2009, 10:47 PM
CL1V3
post Oct 19 2009, 06:44 PM
Comon guys someone must be able to help me lol - please!
AlexS
post Oct 21 2009, 09:45 AM
Drives: black 05 Getz
With diesels, more power is just a matter of adding more boost and increasing the maximum fueling rate.
How new is your car? Is the fuel delivery electronically or mechanically controlled?
To increase the boost don't adjust the actuator rod because you might go the wrong way and the wastegate might leak. Use a boost controller instead and this makes it easier to adjust the boost. Also fit a boost gauge so that you have an idea for how much boost you have.
From there you just have to increase the fueling, otherwise there will be no power gain with just more air...
Removing as much of the restrictive stuff on the intake side as you can is a good idea. Getting a K&N panel or pod filter will improve performance, especially when you have more airflow with increased boost. Removing the cat is bad for the environment! Getting a bigger, high-flow cat converter as well as a bigger diameter exhaust and dump pipe will help with performance too. If the engine doesn't have an intercooler, fit one, otherwise fit a bigger one if it already has one. The intercooler will help to reduce the engine intake air temps with the increase in boost.
Ideally, a bigger turbo sized to the power you want to get should be fitted for the best performance but that, along with intercooler and exhaust starts to add up pretty fast and you may not want to spend that much money. I imagine the standard turbo give about 6 or 7 psi of boost for 80hp. if you wanted 150hp, you'd need a turbo that is ideally suited to deliver the sort of flow rate for that power figure at about 15 psi of boost. Or for 200hp, you'll need 27psi of boost and something around 20 lb/min of airflow (and a huge intercooler to keep the temps down because intake temps will be up towards 100 degrees at that boost level!).
As far as I know, there are still no off the shelf Getz performance dampers. That said, you can still piece together a good kit as a few others and I have done on this forum. Its a mix of Koni parts. If you're interested PM me and I will see if I still have the info around somewhere. Otherwise if you're into spending lots, then there are a few good coilover kits available. Fitting eccentric upper clevis bolts to your front struts/hubs give you a bit of adjustment to dial you camber in a few degrees too.
Finally, I dont know how any of this will help you with smog/registration/etc so just have to be careful what you start swapping out...
CL1V3
post Oct 21 2009, 11:57 AM
hi mate thanks for the advice - my getz is a 2007 reg and i have no idea about if it is mechanical or elctronic :S - if i was to put a panel filter and a decat piece of pipe in (put the cat back in for MOT) would that increase the performance? - im not into chagning the turbo etc but i am interested in how you uprate the boost and fuel - but i need the idiots guide as to how to do it - bearing in mind this car is still under warranty and has to go back to hyundai for one more service etc can the adjustments be made so that they are not soo visable as in could the boost be uprated on the actuator rod as long as its turned the correct way? and which way is taht and is the fuel possible to uprate easily? - as for the suspension could you please let me know where to get the shocks etc and or what fits becuase i really do want/need them! cheers mate - btw i dont think it has an intercooler! its a 16v CRDI 1.5 Getz thats as much as i know i think cheers any more help would be much appreciated
No New Posts Turbo Or Supercharger?
0 matto 2 Yesterday, 10:22 PM
Last post by: matto
No New Posts Getz Door Mirrors Not Working
2 autograss94 13 Yesterday, 02:29 PM
Last post by: autograss94
No New Posts Getz Remote Central Locking
How to fit remote central locking to a Getz
3 agrant 291 14th March 2010 - 03:40 PM
Last post by: engineern6719
No New Posts Please Help Tiburon Shifter Solenoid Has No Ground
3 auto_body_man 34 13th March 2010 - 08:48 PM
Last post by: auto_body_man
No New Posts Topic has attachmentsAdvice On Maintenance Interval Please
21 Indyking 331 12th March 2010 - 09:12 PM
Last post by: sYc
19th March 2010 - 05:32 AM
Privacy Statement
