hi all, ive got a 1.5td getz - i want to know how to improve the performance - i have been told about the actuator for the turbo but i do not know weather to crack the bottom nut and wind the rod further IN to the acuator or further OUT can someone point me in the correct direction and how much to turn it by? also will a panel air filter help and if i take the cat out will that help? any advice would be great and or any other things i could do to improve performance - also i have lowered the car 30mm on gmax lowering springs can anyone tell me where to get performance shocks/dampers because i need them as the ride is strange its not hard and not soft the dampers are allowing too much for the springs so id like performance shocks - any help would be much appreciated - Cheers Clive
This post has been edited by CL1V3: Oct 17 2009, 10:43 PM
