QUOTE (mac1 @ Oct 17 2009, 02:00 PM)
ok, i'm chiming in here one more time because I see your about to make a mistake. Dont touch those vacuum lines as some of them have restrictors in them. If you allready replaced the solenoid and try'd removing the vacuum hose from the EGR valve to improve the idle and succeeded then go ahead and replace the vacuum control valve that's linked to all those vacuum lines. it's supposed to bleed off vacuum at 7 in of vacuum. If it does'nt and all ~20 in of vacuum are going to the egr then the solenoid may not be able to bypass that vacuum back to the engine. Try that and if all this does'nt work time to remove the intake and look for crud inside the EGR valve.
I didn't replace *all* of the lines, just the one from the EGR valve to the vacuum control valve and the one at the top-left of the vaccum control valve to the egr solenoid - why those two? Well, they were both the crappiest of the lot and while I couldn't feel a crack, they were in bad shape so I replaced them just for good measure.
That being said, the car runs a LOT better, but I'm still getting poor idle's at stop lights, after the car has been driven. I'm going to pull the code this afternoon and see what it's telling me now.
Do you have any suggestions/input about what I said earlier about the cross threaded bolt on the pipe from the EGR valve and the new EGR valve not being "seated" on the pipe - but being as tight as I could get it without stripping this new EGR valve? The pipe is only $50, but if that's not an issue, then I'm not spending the $50 (IMG:
style_emoticons/default/smile.gif)
Thanks,
