QUOTE (ElantraBoy98 @ Oct 12 2009, 02:09 PM)
I haven't tried anything yet. Thought I'd seek some input first. Since the car doesn't overheat I assume ther thermostat is working.
The roughness in the idle is erratic and feels like when the alternator is under load. The alternator and water pump run off the same belt so I'm suspicious of the pump.
So how should I check this?
Pumps don't stop pumping, they leak or seize. Maybe someone put on the pump and used too much gasket seal? Maybe your radiator is plugged?
You should be able to see water flow if you take the radiator cap off and run the engine to operating temperature.
In any event, having a loose alternator belt shouldn't make the car run rough. Do you have 13 1/2 volts at the battery under load? If so, there's no problem with the alternator.
If you just changed the timing belt and it runs rough, then I'd suspect they got the timing off when they put on the belt. Remove the top cover and check the sprocket alignment again.
You did the head too? Check the cam sensor. Is the connection good? Did they get the alignment correct when the took off the cam timing chain?
