> 01 2.4 Top End Tick
fbod383
post Oct 10 2009, 12:26 PM
Drives: 01 Hyundai Sonata
I just bought a 2001 Sonata with a 2.4, it has a pretty annoying tick coming from the top of the motor.. Are the lifters serviceable, or do you just replce them?
thanks
fbod383
post Oct 14 2009, 03:44 PM
wow.. no one?
jsinton
post Oct 14 2009, 04:08 PM
Status: Online
Drives: 1999 Elantra
There is no "lifters", it's OHC. It probably means the cams are scored from lack of oil. Maybe somebody stuck synthetic oil in it and plugged up the oil ports.
Attached File(s)
byronguidry3732
post Oct 15 2009, 05:56 PM
Group Icon
Group: Super Mod
Drives: 2009 Kia Sorrento 3.3, 2008 Sonata 2.4, 2003 Tiburon GT 2.7, 2004 Santa FE FWD 2.7
Dear fbod,
Your car has hydraulic lash adjusters. These hydraulically adjust to take slack out of the valve train when you have good oil flow in the HLA's. The HLA has a tiny inlet hole for oil about the size of the tip of a paper clip. If the previous owner failed to change the oil regularly and/or never had an engine flush performed, you probably have sludge clogging one or more of these inlet holes in your HLA's. First fix: try an engine flush treatment to remove/clear the sludge, and a fresh fill of oil. If that doesn't work, second fix is to try a high-mileage oil treatment product like STP Oil Treatment or Rislone. These have a high detergent content to clean out sludge over time. If that doesn't work, third fix is to remove the HLA's and soak in kerosene or mineral spirits over night in an empty coffee can, and use compressed air or Gumout spray carberetor cleaner to blow out the inlet holes. Make sure you completely dry out the HLA's, and soak in regular motor oil before installing.
If that doesn't work, fourth step is to disassemble the HLA's for cleaning. This requires inside snap ring pliers to remove the internal spring and piston assembly.
Byron
jsinton
post Oct 15 2009, 06:12 PM
Status: Online
QUOTE (byronguidry3732 @ Oct 15 2009, 06:56 PM) *
Dear fbod,
Byron
Wow, really good answer. Now I understand what happens when all those people put synthetic oil in their older cars and it gunks up the hydraulic lash adjusters.
fbod383
post Oct 15 2009, 09:05 PM
exactly the info I was looking for. thanks
99son
post Oct 21 2009, 04:37 PM
Drives: 1999 sonata 2.4L
the haynes manual states 2006 and prior have to be adjusted
fbod383
post Oct 21 2009, 05:14 PM
Well.. Haynes has been known to be wrong.. BUT I'm pulling the cover off this weekend.. so I'll let you guys know what i see! Sure makes a **** racket
fbod383
post Nov 3 2009, 07:07 PM
Well.. the lifters a def not adjustable... Its not them thats making the tick anyway. anyone know of other causes of an annoying tick? Its def metal to metal. but not bad enough for a rod or bearing. Does this engine have balance shafts? Does the oil pump tick like a GM when they start to crap out?
cuban
post Nov 3 2009, 07:21 PM
Drives: 1996 hyundai accent 1.5l custom catback, custom cai, stripped interior, new clutch, more to come....
I know if u change the weight in a gm it creates a ticking or knocking sound. See what they call for on th catylist and maye that will help. It did me for my gm.
No New Posts Topic has attachments01 Accent Air Conditioning Compressor Problems
5 clsner 185 Yesterday, 09:15 AM
Last post by: jsinton
No New Posts 01 Santa Fe Overheating,
Radiator fans are okay but won't turn on
8 discoflyer 100 10th March 2010 - 12:05 PM
Last post by: dgreen4298
No New Posts 01 Sonata Falls On Its Face, Then Takes Off Wth!?!
2 fbod383 35 5th March 2010 - 04:34 PM
Last post by: byronguidry3732
No New Posts Top End Tick After Timing Belt Change?
3 sdreese 147 12th February 2010 - 10:04 AM
Last post by: ryanbowser2005
No New Posts Ticking Noise While Moving Over 30 Km/h. Constant.
eight ticks per second, regardless of the speed.
3 flyingcows 388 7th January 2010 - 07:57 PM
Last post by: WOT
14th March 2010 - 07:17 PM
Privacy Statement
