QUOTE (peaches6544 @ Oct 3 2009, 06:24 PM)
First of all my radiator has a leak and it shot allover ,but we also changed spark pugs now car engine wont turn over
I can answer a few of the questions about the car's condition. I have been trying to help diagnose the trouble. The car has a bad radiator. Based on watching smoke (steam) come out of the top near the front of the car. I saw this when the car was cranking. I could also see radiator fluid in many areas of the engine, so it was definitely spraying. The engine did start at first and we were waiting for it to come up to tempurature, hoping that the radiator leak would fully reveal itself. We shut the engine off for a few minutes to take a peak at hoses, etc... Then when we tried to re start the car to take it for a ride around the block, it would not start and run steady. Every now and then it would try, but a further tap of the accelerator and it would shut down. We pulled all four plugs to see if there was something od going on, but the all seemed normal. Replaced them and the wires, just the same, but the same condition existed. Car will not start. Hopefully that helps.
I'll do a search here to see how to pull codes. Hopefully it is only a sensor or something simple. What do you guys think??
