Howdy,
I have a manual 2002 Elantra GT. I recently had diagnosed (AutoZone read the codes) misfires in cylinder 2. I fixed that by starting with the plugs, then wires, but ultimately a new coil was the solution. I also (still) have high RPMs at idle and when I push in the clutch. The RPMs will vary from 1.5 to 3K after it is at operating temp. Looking around the forum I've read about similar problems and suggestions to replace the TPS. The check engine light is not on so I'm reluctant to take it in to the dealer without giving them something to go on. I can replace the TPS but shouldn't there be a code or some indication that it is bad if the idle speeds are all over the place? Thanks!
