> 1992 Excel Fuel Pump?
Dejaud
post Sep 30 2009, 09:31 PM
Drives: 92 excel
Where would I find it?
Motokitn
post Oct 2 2009, 09:57 PM
Drives: 09 Santa Fe
When I had my 92 I was told the pump is in the tank.
sanjeet
post Oct 4 2009, 04:17 AM
Drives: 1992 Hyundai Excel LS
I have a Haynes manual and this is for a New Zealand assembled Excel, the manual describes the mechanical fuel pump being below the inlet manifold so its at the rear of the engine and from what the manual is telling me you need to jack up the car and fit axle stands and get to it from underneath the vehicle, the manual also say'syou should fit new gaskets and notes QUOTE: Where the push rod is located on the apex of the camshaft eccentric, it will be difficult to to insert and tighten the mounting bolts, Where this is the case position the engine at TDC before fitting the pump.
It is easy to set no.1 at TDC , remove the spark plugs and you can see the piston crown moving up to TDC align that with the timing marks on the pulley and timing guide marks.
maxwell12
post Dec 25 2009, 10:23 PM
Drives: HYUNDAI EXCEL
this pump should be inside the gas tank..also replace the gas filter when you are in there..good luck..I read somewhere yoou have to soder the electrical ends of the fuel pump in order to attach it..hope this helps
No New Posts Fuel Pump 2006
6 dbagsoh 145 15th March 2010 - 07:53 PM
Last post by: jsinton
No New Posts Fuel Leak
1 pat1958 15 15th March 2010 - 06:08 PM
Last post by: Montego
No New Posts Topic has attachmentsFuel Flap Not Opening
1 couchwarrior 53 13th March 2010 - 02:48 AM
Last post by: andycarter
No New Posts Topic has attachmentsFuel Tank Air Filter On 2.7l
10 Frank G 142 12th March 2010 - 08:21 PM
Last post by: canderson
No New Posts Fuel Pump Runs After Parking And Shut Off
4 Keith S 101 11th March 2010 - 07:35 AM
Last post by: Keith S
20th March 2010 - 11:05 PM
Privacy Statement
