Way To Change Gauge Cluster Lighting Color? |
Sep 18 2009, 03:24 PM
Status:
Drives: 2006 Hyundai Sonata LX
You can replace led lights by yourself. It is not a painful job. Order 3528 PLCC2 led from below link and ask anyone who knows electric circuit soldering. http://www.oznium.com/plcc-2
This post has been edited by sunny68: Sep 18 2009, 03:34 PM
Sep 20 2009, 02:04 AM
Jack of All Trades; Master of None
Status:
Drives: 2006 Hyundai Sonata GLS 3.3L V6 (DOB 11/08/05)
QUOTE (Arrone @ Sep 19 2009, 10:43 PM)  Would it void my warranty though? It will void the warranty on the specific components you solder (i.e. gauge cluster, clock, HVAC, switches, etc.), but not on the entire car.
Nov 21 2009, 10:45 PM
Status:
One of the LEDs died on my HVAC controls and I've done the steering wheel buttons, the dome light and put a couple cathodes under the dash. I still have to do the clock, but I don't see how you can get it out. I know there's two screws, I'm able to get the bottom one, but it looks like I might have to take the whole front panel off. ALSO, my dang CD player isn't working. Apparently one of the CDs got stuck and I've tried prying it with a flathead..but still nothing. This is just great. (IMG: http://i55.photobucket.com/albums/g139/Arrone_MP/HPIM0007.jpg) (IMG: http://i55.photobucket.com/albums/g139/Arrone_MP/HPIM0008.jpg) (IMG: http://i55.photobucket.com/albums/g139/Arrone_MP/HPIM0009.jpg)
This post has been edited by Arrone: Nov 21 2009, 10:46 PM
Nov 22 2009, 02:29 PM
From: Indianapolis, where every Tercel is an Indy Car
Status:
Location: Indianapolis, where every Tercel is an Indy Car
Drives: "KC" 06 GLS V6 Bright Silver Metallic *** Paid for ***
I removed my clock to change the LEDs. You have to remove the radio, center console, glovebox, passenger side trim, driver side trim, THEN you can get access to all the bolts, screws and clips holding the front fascia in. After I removed the front fascia I saw all the screws holding in the clock/front passenger airbag light. IIRC, it's one big piece. I don't think there's any other way to get it out because of the placement of the 3 (?) screws.
If you're comfortable removing the interior panels, you shouldn't have much difficulty. Although the above list looks long, it only took me 2 hours to get everything off.
Nov 22 2009, 07:18 PM
Status:
Drives: 2006 Sonata, Steel Grey, born June 4, 2005
QUOTE (Dennis the Mennis @ Nov 22 2009, 01:29 PM)  I removed my clock to change the LEDs. You have to remove the radio, center console, glovebox, passenger side trim, driver side trim, THEN you can get access to all the bolts, screws and clips holding the front fascia in. After I removed the front fascia I saw all the screws holding in the clock/front passenger airbag light. IIRC, it's one big piece. I don't think there's any other way to get it out because of the placement of the 3 (?) screws.
If you're comfortable removing the interior panels, you shouldn't have much difficulty. Although the above list looks long, it only took me 2 hours to get everything off. That's alot of extra pieces to remove. When I removed mine I took out the HVAC and the radio to gain the needed access. Then used a combination of a shorty screwdriver and a 90-degree bent driver and got it out.
Nov 23 2009, 07:35 PM
Status:
QUOTE (hugamuto @ Nov 22 2009, 11:54 AM)  I think you added the redline a little to early ;) Heheh, don't feel like taking the gauge cluster out and swapping only one LED out. As for the clock, I did the way hideftv used. Gotta be careful with the clock buttons though, those buttons just jump everywhere haha. Get it away from the dash board or you'll risk it being lost.
Similar Topics
Similar Topics
