QUOTE (StevenWang @ Sep 16 2009, 10:33 AM)
yeah.pretty much what the d00d aboe me said. if you can do the work, the ebay one is fine for sure. you got ur intercooler, the piping, a bov, a turbo etc. you can always upgrade ur turbo. its tedious work though. not something you can do in a day with a universal kit. plus ur gonna have to find room to put ur turbo in and get everything in there properly as opposed to a "bolt on" kit. good luck.
I have been building turbo engines for quite some time and I will tell you DONT BUY A EBAY TURBO. Any turbo will bolt up to the proper manifold, that is not the issue with the ebay turbos. The issue is they are made out of cheap parts. There is a reason why a mitsubishi industries 16g is $500 and a EVOIIGT ebay knock off is $275. You can make your own turbo kit if you understand how the whole system works.5k for a kit is outrageous unless you are getting a journal bearing turbo or equivilent, which I highly doubt you are.
