 Hyundai-Forums.com > Hyundai Models > Entourage Forum
> Flasher Unit Location
Euphonius
post Sep 15 2009, 09:56 PM
Drives: 2007 Hyundai Entourage 3.8
When I turn on the right turn signal on my 2007 Entourage, it usually works OK, but sometimes it flashes extremely fast. The left turn signal works fine. I suspect there's a problem with the flasher unit. But where is it located? Thanks.
jsinton
post Sep 15 2009, 10:20 PM
Drives: 1999 Elantra
Unfortunately, the flasher unit is integrated on to the BCM from what I understand. That means you have to be a wiz with a soldering iron and know where to purchase the correct component, or you just buy a whole new BCM. Look in you owners manual, fast flashing might mean burnt out bulb or something.
alex2006sonata
post Sep 16 2009, 09:28 PM
Expert
Drives: 2006 Sonata GLS w/ 3.3L (Me), 2008 Entourage Limited (Wife)
Yea normally a fast flashing sensor means you have a burnt out bulb. Might be worth spending the $3-5 and replace the front and rear turn signal bulbs, or if possible check both the rear and front when its blinking fast to see if either of the bulbs aren't working.
Euphonius
post Sep 19 2009, 10:41 PM
Thanks to both of you. You were right. The problem was only a burned out bulb. It was a relatively easy fix with directions in the owner's manual. Euphonius.
No New Posts Location Of Egr Valve
Where is this PITA?
5 johnnymass 162 18th February 2010 - 11:47 AM
Last post by: PoMansAWD
No New Posts Location Of The Transmission Drain Plug On 2007 Azara
10 tomngerry 431 28th January 2010 - 04:48 PM
Last post by: TheWidowsSon
No New Posts Location Of Oxygen Sensor
ECU Problems
0 Shariq 717 2nd December 2009 - 08:54 AM
Last post by: Shariq
No New Posts Location Of Diagnostics Port In 2006 Tiburon?
2 djphatd 123 13th November 2009 - 07:37 PM
Last post by: djphatd
No New Posts Topic has attachmentsLocation Of Ac' Filter
1 Ramy 107 13th September 2009 - 06:49 AM
Last post by: jsinton
20th March 2010 - 03:33 AM
Privacy Statement
