> 02 Accent Speedometer Isn't Working After Clutch Replacement
Kevin W
post Sep 7 2009, 12:11 PM
Drives: 2002 Hyundai Accent 1.5, 5 Speed
I just replaced the clutch on a 02 Accent, and now the speedometer isn't working. The speedometer is driven by a cable that hooks into the differential. Taking the cable off I really don't see how the cable is able to spin, like maybe a part fell off into the differential? Here's a couple of pictures of what I've got. Any ideas?
(IMG:http://www.iwilliams.org/images/h1.jpg)
(IMG:http://www.iwilliams.org/images/h2.jpg)
(IMG:http://www.iwilliams.org/images/h3.jpg)
(IMG:http://www.iwilliams.org/images/h4.jpg)
jsinton
post Sep 7 2009, 12:17 PM
Drives: 1999 Elantra
Looks like the little nylon gear fell out of it. It's supposed to have a gear on the end. Is it on the floor, or is it still stuck in the trans?
Kevin W
post Sep 8 2009, 03:09 PM
Thanks for the info. I called the dealer and ordered the part. I'm going to try to drain the oil and see if I can find it in there as the part's a good week+ out.
jsinton
post Sep 8 2009, 05:41 PM
Let us know how you make out. How much does the gear cost?
rsquared
post Sep 12 2009, 10:29 PM
Drives: 2002 Hyundai Accent GL 1.6 DOHC
You sure it's not the cable that's broke?
mac1
post Sep 12 2009, 10:41 PM
Drives: 2001 XG, '01 Accent 1.6L, '98 Explorer Sport, '95 Probe GT-Turbo weenie
QUOTE (rsquared @ Sep 12 2009, 11:29 PM) *
He's right, it's not a gear it's the cable that seems broken. The end of the cable that is inside is supposed to protrude out about 1/4 inch andhave like a keyway on it. If you forced it on without lining up the the key then it snapped and is probobly sitting in the sensor part right now.
Kevin W
post Nov 20 2009, 03:09 PM
QUOTE (mac1 @ Sep 12 2009, 11:41 PM) *
Ok, I got the thing fixed and it wasn't pretty. I put in a new speedometer and it shredded the nylon gear in about 2 miles of driving. Meanwhile the transmission now is leaking gear oil through the input shaft in bell housing. I got a supposed seal and new speedometer, dropped the tranny but the seal is inside the transmission. I took the transmission apart and the seal was the wrong one.
Also I found the old speedometer gear and it was bashed up pretty good along with the gear on the ring on the differential. I figured it would be pretty hard to find a replacement and I didn't want to mess with setting up a new differential so I ended up purchasing a used transmission for $350.
So... moral of the story is that when you are removing the tranny disconnect the cable near the transmission (it'll unscrew) and don't take off the 10mm bolt that holds it in place on the transmission case as it might (as in my case) drop down into the belly of the differential and get chewed up when you take it off.
Montego
post Nov 20 2009, 03:36 PM
Administrator
Group Icon
Group: Administrator
Status: Online
Drives: XG's (2001&2002)
well you won't do that again kevin, but glad to hear you've finally got it sorted (at a price)
No New Posts Accent 95 Has 2 Radiator Fans ?
0 CarlosFreitas 5 Today, 08:16 AM
Last post by: CarlosFreitas
No new Pinned: Topic has attachmentsReplacement Dvd/gps/tv/bluetooth Unit
709 glospete 49,174 Today, 07:40 AM
Last post by: asathorny
No New Posts Aftermarket Throttle Body
anyone have any luck finding one???
12 maddnotez 249 17th March 2010 - 01:06 PM
Last post by: NubR1
No New Posts Clutch Problems
0 Jesse James 24 16th March 2010 - 10:33 PM
Last post by: Jesse James
No New Posts Accent Engine Swap
Accent engine swap 1.5
6 xxnamxx 228 16th March 2010 - 09:02 PM
Last post by: 1x32go
19th March 2010 - 12:34 PM
Privacy Statement
