 Hyundai-Forums.com > Hyundai Models > Amica & Atoz Forum
> Amica Exhaust Trouble
granicv6
post Sep 4 2009, 07:02 AM
Drives: hyundai amica si
hia all
i have a 2001 amica si with the following symptoms the car drives like its being held back this feeling clears after a while and the car drives better.have changed the ht leads and coil pack as it was misfiring aswell,upon driving it last night i noticed the gear stick and suround getting hot,when i looked under the car the cat was glowing red?
has anyone had similar problems..
someone sudgested that my back box was blocked..any thoughts
thanks for looking
jsinton
post Sep 4 2009, 07:07 AM
Drives: 1999 Elantra
The CAT is supposed to glow red, but that doesn't mean it isn't blocked. Problems like this should produce a trouble code. Did you do a code scan?
granicv6
post Sep 4 2009, 07:10 AM
no havnt done scan yet
jsinton
post Sep 4 2009, 07:18 AM
Usually a collapsed CAT means you have other problems. Like antifreeze leaking into exhaust, or too much injector cleaner, or even as simple as you drive too hard and burned it up. Or maybe you used leaded petrol?
granicv6
post Sep 5 2009, 02:37 PM
did an engine flush today an oil change an a new filter,cars better but still feels like its being held back will check the exhaust tomorow any sugestions??
DaviesBrown
post Oct 5 2009, 05:00 AM
Drives: Maruti WagonR
Hello
Features of the Circuit
* By any chance if high combustion temperatures are created by oxides of nitrogen then an Exhaust Gas Re-circulation EGR system which is the chief feature of this system will be boosted to counter this.
* This is done by supplying small amounts of exhaust gases back into the combustion chamber.
* Combustion temperatures are minimized as soon as the air/ fuel mixture dilutes the exhaust gases.
* The EGR valve has been specially designed to generate exhaust gases to the engine without using intake manifold vacuum.
* This valve regulates exhaust flow entering the intake manifold from the exhaust manifold through an orifice with an ECM controlled pintle.
* The pintle position is monitored by the ECM using inputs from the Throttle Position (TP) and the Manifold Absolute Pressure (MAP) sensor.
* This task over, the ECM then directs the EGR valve to operate as necessary by controlling an ignition signal through the ECM.
* The ECM further monitors the results of its command through a feedback signal.
* The desired EGR position can be checked with the help of a scan tool.
* A voltage signal representing the EGR valve pintle position is sent to the ECM by a 5 volt reference and a ground to the EGR valve.
Ratchet Straps
This post has been edited by DaviesBrown: Oct 6 2009, 01:05 AM
plumer
post Nov 16 2009, 01:58 AM
Drives: 1995 Mitsubishi Eclipse GS-T
QUOTE (DaviesBrown @ Oct 5 2009, 06:00 AM) *
Hello
Ratchet Straps
Yes i had the same problem but i had not done the scanning
No New Posts Exhaust Questions ?
10 sherifsabet 1,314 11th March 2010 - 08:07 AM
Last post by: blackbullet
No New Posts Exhaust Compromise
If you don't really want to change your exhause . . .
3 Redryder 173 17th February 2010 - 11:40 PM
Last post by: Don67
No New Posts Exhaust Upgrades For A 2009 4cyl Sonata?
any ideas?
3 sdchargers21ap 211 13th February 2010 - 01:19 AM
Last post by: maddnotez
No New Posts Amica Water In Oil Cap
Water in Oil Cap
1 AmicaBob 242 12th February 2010 - 03:49 PM
Last post by: Montego
No New Posts Trouble Codes From Obd-diag
Anybody knows this codes?
1 Loif 103 9th February 2010 - 05:42 PM
Last post by: jsinton
21st March 2010 - 06:17 AM
Privacy Statement
