***About TSBs, don't treat these like recalls... this is just meant to help sevice tech to solve common problems on particular cars. Unless they find these specific codes, it doesn't apply to your case.***
Unless it's flashing, it should be fine to drive.
Gas cap is tight? Drove over a 100miles since you check it? If it was the cap, it would have shut off by itself I think.
If you pass near a dealer, I would have them just read the code. That way, they can't blame you if more damage is ever done.
In my case, My new Elantre triggered the light right @ 500km Read the code myself with my Scantool: P0455. Car was in the shop twice for it: 1. They reset the code and test the EVAP System with success. 2. Code came back after 150km. They reset the code again and test again with success... but since I insist this is the 3rd time the light comes ON on a brand new car in less than a month. They guessed they should replace the EVAP Solenoid, and that they were 90% sure this would solve it.
1500km later, still haven't come back. So they seem to have fixed it right this time.
This post has been edited by MarioT: Oct 23 2009, 09:22 AM
