> P0037 Still There
pjm123a
post Jul 27 2009, 10:04 PM
Drives: 2002 Sonata GLS
Hi
Have a 2002 Sonata - V6 GLS - Love the car - has about 114k of mostly trouble free driving.
I'm hoping to get 200k out of it :-)
Lately though, I've been battling my check engine light. It complains about he same thing:
P0037 HO2s Bank 1 Sens 2 Heater circuit low.
I have replaced the oxygen sensor with one from Bosch. This was
a direct plug-in replacement. When I did that the check engine light went out on it's own.
I did not have to erase it. After a couple of weeks it has come back on. The code is the same.
I've also replaced a fuse in the box under the hood.
Any ideas of what to do next.
I've seen a few other posts on this forum where some other folks have had this problem.
What was done to finally resolve it?
byronguidry3732
post Jul 31 2009, 11:18 AM
Group Icon
Group: Super Mod
Drives: 2009 Kia Sorrento 3.3, 2008 Sonata 2.4, 2003 Tiburon GT 2.7, 2004 Santa FE FWD 2.7
Dear pjm,
You may be suffering from connector corrosion. Since you said you paid the extra and bought the Bosch direct replacement, that should not be the problem. Get some spray electrical cleaner. disconnect the O2 connector, spray with cleaner, and work the connector in and out 5 times, spray again, blow or wipe off excess, and reconnect.
Byron
pjm123a
post Aug 4 2009, 09:40 PM
Hi Byron,
Thanks for the suggestion. I can only hope it is something that easy.
I gave it shot tonight. Sprayed some cleaner on the connector.
plugged and un-plugged a few times. cleared the code.
So far so good. We'll see if it stays off.
Thanks again
cashflo
post Aug 13 2009, 08:35 AM
Drives: 01 sonata
Did cleaning the connectors work?
pjm123a
post Aug 14 2009, 10:07 PM
QUOTE (cashflo @ Aug 13 2009, 09:35 AM) *
It looked like it did for a little while, but then the light came back on (sigh).
Next I;m going to clear it. Then one at a time, I'm going to disconnect
the sensors till I get the same code. I'll try cleaning that one real good.
pjm123a
post Oct 25 2009, 10:53 PM
OK, after lots of trial and tribulation, I'm pretty sure I have finally solved this.
I ended up replacing both bank 1 oxygen sensors. The light has gone out on its own and so far
is staying out. I used the bosch direct replacement sensors. I really think I nailed it this time.
I have a much better sense of how the sensors work. The bank 1 sens 2 was tricky to find.
I'm glad that it its fixed. The car never seemed to run bad when the light was on, but I must
admit that it "feels" better now (might be all in my mind).
pjm123a
post Oct 31 2009, 09:30 AM
Just an update - Its been a couple of weeks now and the light is still out. Car is running fine.
In retrospect, I probably replaced the wrong sensor initially. Fortunately, I kept the old one
since it is probably still good. If anyone needs these sensors, advance autoparts has them
for right around $100. They are not that hard to replace. In particular the second one I did
has an access plate that covers it. Removing 2 screws makes it easily accessible.
Thanks to everyone for their suggestions.
pjm123a
post Jan 6 2010, 09:08 PM
Just in case anyone is still following this. The fix is solid. No more check engine light for months now.
Next up: change transmission fluid, then the dreaded timing belt!
No New Posts There And Back Again.
Thousands of miles of Accent Reliability
3 Maxpow 208 1st February 2010 - 09:18 AM
Last post by: royalbrett
No New Posts Still Not Starting..
Alternator???
3 tweetyb66 88 9th September 2009 - 08:08 AM
Last post by: jsinton
No new Still Selling Azera
27 heypal 712 2nd August 2009 - 01:10 PM
Last post by: andyman32
No New Posts Still Waiting
Still no delivery date available
8 rickandberyl 373 11th July 2009 - 03:22 PM
Last post by: danburgerz
No New Posts Still Loads Of Good Bits Left
0 dmsully 292 21st May 2009 - 03:29 AM
Last post by: dmsully
16th March 2010 - 09:13 AM
Privacy Statement
