> Wet Carpets
wdavie
post Jul 17 2009, 09:19 AM
Drives: 2000 XG30
Hi all i've noticed recently that the carpet behind drivers seat, UK, and in the boot is soaking wet, it also seems wet underneath the rear seat. Could water be coming through the wheel arch somehow. Just wondered if anyone else had experienced this problem. Thanks
Wayne
Montego
post Jul 17 2009, 11:55 AM
Administrator
Group Icon
Group: Administrator
Status: Online
Drives: XG's (2001&2002)
the most likely cause is the rear screen leaking, put the rear seats down and then stay inside the car while a friend sprays the car with a hose pipe...try and see where the waters coming in
thafinestxg300
post Oct 1 2009, 07:03 AM
Drives: 2001 xg300L 1987 mustang gt
my front passenger does the same thing same steps mont?
accent sport
post Oct 1 2009, 10:32 AM
Drives: Accent 08 1.6 DOHC cvvt
It's also a good idea to check and make sure that all of the floor drain plugs are in place and secure, If they are missing replace them right away and make sure that you dry the carpets fully or they will be full of mold in no time at all. (IMG:style_emoticons/default/thumbsup.gif)
E43509
post Oct 12 2009, 10:23 PM
Drives: 2004 Xg350, 2003 elantra, 2002 santa fe, 2001 Tiburon
Also check the AC drain line. There is a little pan that holds the condensation from the AC and that has a hose to drip onto the road under your car. If the line is blocked, the pan fills and it can overflow into the passenger compartment. If the line is blocked, you can typically use an air hose to blow it clear.
hyundainator
post Oct 18 2009, 03:41 PM
Drives: 2002 Hyundai XG350
I had a trunk full of water recently. I found a drip at the corners of the rear window at the bottom. With the trunk lid open, you can see along the bottom edges where the seal is split and thats where mine was leaking, I got up inside the trunk with some sealant, and fixed the dripping. Now for the door/window rubber leaking, thats going to be hard to fix. Nature of the beast I think.
P.S. The above suggestion about the floor plugs is a good one. I had two rubber grommets in the trunk floor that were not seated any longer. Pushed them back down with some sealant on them for now.
Montego
post Oct 18 2009, 05:06 PM
Administrator
Group Icon
Status: Online
QUOTE (hyundainator @ Oct 18 2009, 09:41 PM) *
all those leaks on a 2002 model is pretty bad, do you get alot of severe weather where you are
hyundainator
post Nov 2 2009, 06:13 PM
My car was in a rear end collision, and I bought it to fix up. Im sure that didnt help it any. Its tight now, as we have had record breaking rainfalls lately and no leaks. Well aside from the drivers window at the top, it leaks in heavy heavy rain while on the highway.
No New Posts Wet Carpet & Mat In Drivers Side Footwell
3 justlikeeeyore 113 25th January 2010 - 11:40 AM
Last post by: justlikeeeyore
No New Posts Wet Floor Mats
help
16 nir_rs 490 9th December 2009 - 12:07 PM
Last post by: tommibennett
No New Posts Wet Weather Probs
my Atoz dies after 1/2 mile!
4 muddypaws 1,709 11th April 2009 - 03:24 AM
Last post by: elaine1015
No New Posts Wet Sanding
0 hyundaiguy 393 13th October 2008 - 02:34 PM
Last post by: hyundaiguy
No New Posts Wet Coil And Plug
2 hound 364 12th September 2008 - 04:24 AM
Last post by: Torbo1
11th March 2010 - 05:29 AM
Privacy Statement
