Need to know more details about your car, but most seem to be solved by doing this:
System operation
Pressing remote control lock button locks vehicle and activates system Indicators flash once. Pressing remote control unlock button unlocks vehicle and deactivates system Indicators flash twice.
When
Remote control added or replaced. System malfunction.
How
1, Access alarm system control module located under driver's side lower fascia 2, Set memory switch to SET position. 3, Press remote control lock or unlock button. 4, Set memory switch to OFF position. 5, Confirm synchronization has been successful by locking and unlocking vehicle. 6, Repeat procedure for second remote control. 7, Synchronization can also be carried out using diagnostic equipment.
NOTE: A maximum of 2 remote controls can be programmed. NOTE: If remote control fails, system can be deactivated as detailed in the owner's handbook.
Hope this helps,
Phil
