09 Sonata Gls Steering Vibration At 70mph |
Jul 2 2009, 11:11 PM
Status:
Drives: 2009 Hyundai Sonata GLS
Hi, I'm new here
I just bought a new GLS sonata on monday, and
been driving it for about 150 miles, now and I noticed
that the steering vibrates excessively past 65 mph.
I went in to the dealership today, and they said
they adjusted my rotors, and it should be fine,
but I am still experiencing the vibration,
and also when speeding down from 70 to about 30
to get to an exit from a highway I feel abs like pulsing
in my breaks. i read a few threads on here about similar problems,
but they were all on older models. I was wondering
if these were also common problem people were experiencing
on the 09 sonata, and how I should go about fixing it.
Please help me! this is my new baby, and I'm really scared!
Jul 3 2009, 12:21 AM
Jack of All Trades; Master of None
Status:
Drives: 2006 Hyundai Sonata GLS 3.3L V6 (DOB 11/08/05)
QUOTE (dltmdgud @ Jul 2 2009, 11:57 PM)  I mean is this normal?
should I try the dealer few more times, and
try to take advantage of the lemon law?
I only had the car for 4 days, and the car only had 4 miles, when I bought it
I'm just worried this might be a bigger problem This is absolutely NOT normal. My 3-year old Sonata doesn't vibrate, your 3-minute old Sonata shouldn't either. If you feel comfortable with your dealer, give their service department a shot at it. You may be one of the lucky ones with a good dealer. I'm almost sure it's got something to do with balance. Several other people have had the same or very similar issues with their brand new Sonata's. From what I recall, it's always related to balance problems. Although not impossible, it's unlikely that it's a bigger problem. If a rebalance doesn't stop, or at least reduce, the vibration, there may be a problem with one of the suspension components. In that case, get the dealer to fix the problem under warranty. If a rebalance reduces the vibration, but doesn't stop it, try having the tires remounted, or if you're lucky, replaced. This will likely solve the problem. It's too early to cry "LEMON!" You'll need to give the dealer plenty of chances to fix it before pursuing this option. Then it will take some time getting through the legal process. And ultimately, Hyundai and your dealer will hate you in the long run. It sounds like a trip to the dealer is in order. Good luck, and let us know how it all turns out.
Jul 3 2009, 07:07 AM
Status:
Drives: 2009 Sonata GLS 2.4
I've owned 2 Hyundais and they both had a vibration in the steering. One vibrated when I applied the brakes. The car had been on the lot for a few months and the rotors rusted around the caliper pads and needed to be resurfaced. Easily resolved by the dealer. My Sonata vibrated at 65-70 while NOT applying the brakes. Dealer rebalanced the front wheels. That fixed the problem. You may have a combination of both problems. It should be easy to fix but I would insist the dealer get it right. That's why you pay for a new car.
Also, these types of problems can happen to any car. Not uncommon at all.
This post has been edited by ems1: Jul 3 2009, 07:07 AM
Jul 8 2009, 02:52 PM
Status:
Drives: Sonata 2009
Well why should they take the time to balance any of the tires BEFORE they sell the cars, when they can charge the customer for it after the sale. (IMG: style_emoticons/default/thumbsup.gif)
Jul 21 2009, 11:42 AM
Status:
I purchased an 09 GLS last week and had a bad vibration at speeds around 65-70 as soon as I left the dealer. I went back to the dealer and had them balance the tires. When I left, the problem was a little better but definitely still there. The service manager took it for a ride and noticed also. They are going to keep it for a day to see if they can figure out the problem. I will let you know what they find out and if they fixed it.
Jul 21 2009, 11:53 AM
Status:
Drives: 2009 Hyundai Sonata GLS 2.4L
I haven't gone above 55 mph because I'm trying to follow the breaking-in instructions from the owner's manual. I can't really comment over that speed.
When I first drove at higher speeds, I did have some minor shaking. After a few miles, it resolved. My thought is that many times these Sonatas are just sitting in the lot for too long. The tires become flattened on one side because they haven't been spinning. One Sonata I was going to test drive only had 8 miles...but it wouldn't start! The battery was drained or the starter was shot. I think that kinda shows that a lot of those cars just weren't driven.
Jul 28 2009, 11:33 AM
Status:
QUOTE (WTLHYUNDAI @ Jul 21 2009, 12:42 PM)  I purchased an 09 GLS last week and had a bad vibration at speeds around 65-70 as soon as I left the dealer. I went back to the dealer and had them balance the tires. When I left, the problem was a little better but definitely still there. The service manager took it for a ride and noticed also. They are going to keep it for a day to see if they can figure out the problem. I will let you know what they find out and if they fixed it. The dealer kept the car for two days and when I got it back, it did the same thing. I took it in for a third time and they swapped all 4 tires and wheels off of another new car. I finally got it up to highway speeds today and there is still a small vibration above 65 mph. I am still deciding to live with it or take it back for a full refund or new car under Lemon Law. (Ohio Lemon Law is 3-Times for same problem and if it has to go back a 4th, it is considered a lemon). I just wish I had a trouble free new car and it seems like a simple fix. I don't know if the dealers balancing equipment is as good as a standard tire dealers and I don't want to have to pay for something out of my own pocket when I should not have to. I will let you know what I decide.
Jul 28 2009, 01:31 PM
Status:
QUOTE (Dennis the Mennis @ Jul 28 2009, 12:46 PM)  If the dealer swapped all 4 wheels off another vehicle and you still have a vibration, it's neither the rims nor the tires. Something in your suspension has a resonance or sympathetic vibration. The tranny's ruled out or you'd have vibrations that come and go as you accelerate.
Did the dealer put a mechanic's stethescope on each wheel bearing and test drive? Many times a bad wheel bearing squeaks in time with the vibration. There is very little communication between what was done by the mechanic and what the person working the service counter is told. They only tell me each time that they fixed it and that it was just a tire out of balance which make we question whether or not they know what they are doing because if they just balanced them, then they should not be out of balance 5-minutes after I leave the dealer. I did get a little better after they changed the wheels and tires which tells me that was part of the problem, but there is no way to know if the tires and wheels they put on were balanced since they seem to have a problem with balancing. I agree that it could be something else (ex. undercoating on a drive axle, bent drive axle, or bearing) but the fact that it only has the vibration above 65 makes me think it is a balance problem. By the way, you asked if they used a mechanic's stethescope on each wheel bearing and test drive. Is there such a thing as a remote style of stethescope that allows you to attach it to something in the car and listen for a noise while on the road? I only have the old doctor probe looking kind and would love to have something like that to diagnose problems.
Aug 24 2009, 11:20 AM
Status:
QUOTE (WTLHYUNDAI @ Jul 28 2009, 02:31 PM)  There is very little communication between what was done by the mechanic and what the person working the service counter is told. They only tell me each time that they fixed it and that it was just a tire out of balance which make we question whether or not they know what they are doing because if they just balanced them, then they should not be out of balance 5-minutes after I leave the dealer. I did get a little better after they changed the wheels and tires which tells me that was part of the problem, but there is no way to know if the tires and wheels they put on were balanced since they seem to have a problem with balancing. I agree that it could be something else (ex. undercoating on a drive axle, bent drive axle, or bearing) but the fact that it only has the vibration above 65 makes me think it is a balance problem. By the way, you asked if they used a mechanic's stethescope on each wheel bearing and test drive. Is there such a thing as a remote style of stethescope that allows you to attach it to something in the car and listen for a noise while on the road? I only have the old doctor probe looking kind and would love to have something like that to diagnose problems. I went back to the dealer for the 4th time last week. Hyundai had the regional rep come and drive the car. The rep said they felt nothing but had the tires road force balanced anyway. They said it is operating normal. I am now ****. The dealer all along has agreed that there is a vibration when they rode in the car with me, but now that the rep can't figure out what the problem is, they just say it is normal. I have had many people in the car as passengers and as drivers and they have all told me (without me telling them about the problem) that there is an vibration in the steering wheel. I even took video of the steering wheel rocking back and forth about a total of an inch when I get above 65 mph. The vibration comes and goes. Some days it vibrates my entire commute, some days only for about 5 miles. I asked the dealer to take the car back and they said that since I have 2,000 miles on it that they wouldn't because it is now a used car. They said if it only had 200 miles on it, that would be different even though I originaly starting to bring the car to them for this problem the day after I picked it up with only 40 miles on it. I have now entered arbitration under lemon law. I will let you know what happens.
Similar Topics
Similar Topics
