QUOTE (nev @ Jul 2 2009, 01:34 AM)
Gidday, this is my first, so go easy on me!
I'm trying to get an aftermarket tacho to work in my EFI distributorless 1.5. I have found tacho power, earth & instrument backlight tap-inable points on the centre plug on the back of the instrument cluster - there are 3 wires in a row next to each other: black(earth), white(backlight), and blue/black(tacho power).
The circuit diagram in the manual also shows a white wire coming into the tacho. This wire is not present on the centre plug of the instrument cluster!
My problem is: do I have to find a (one & only one of them I hope!) white wire coming straight out of the E.C.U. main plug & tap into that, or as I was juist reading do I need an isolator circuit of some sort? I'm just a bit nervous (sorry-VERY nervous) about this & I want to be sure so I dont destroy the E.C.U. So at the moment I have a tacho that lights up nicely even though it says I'm doing no revs when I actually am! I would appreciate anyone's help on this, & I hope to be able to help someone else in the future on this forum if I can
