OK, I finally got around to installing my HID's and creating this write up. I hope it is helpful!
Here is the place that I ordered my lights from:
http://www.ddmtuning.com/index.php?p=produ...2&parent=85 (thanks to ddix!)
I went with the 4500K, so they are not too blue. Also, I bought their "Error Code Eliminator - 3" to keep my computer happy, just in case. In the end, the whole deal cost less than $100 with shipping and the installation took me about an hour (granted I was taking pictures). The only thing that I would say is not so great about this kit is that the instructions provided in the kit are absolutely useless. However, you now have my step by step, and in the end, it is an easy install!
So, with out further delay, here is the installation!
Step 1:
Number of downloads: 49Remove the headlight assembly. It is not hard, and it makes the installation much easier.
Step 2:
Number of downloads: 51This bolt is the hard one, and it does take a little bit to get it out!
Step 3:
Number of downloads: 44Remove the multi plug attached to the assembly.
Step 4:
Number of downloads: 33Once you have removed the headlight assembly, you will need to remove this dust cover to access the OEM bulb (be sure that you are accessing the low beam bulb).
Step 5:
Number of downloads: 47After you have removed the low beam dust cover, unplug the OEM bulb and release the retaining spring.
Step 6:
Number of downloads: 65This is the HID bulb that comes in your kit (you get two of them), and the picture shows what parts you keep and what parts you discard.
Step 7:
Number of downloads: 53You will need to drill a 7/8" in your low beam dust cover to allow the HID bulb's wires to pass through.
Step 8:
Number of downloads: 62This shows the correct way to connect the power wires from the HID bulb into the connector that was attached to the OEM
bulb.
Step 9:
Number of downloads: 55Pull the remaining HID bulb wires through the low beam dust cover. Then pull the grommet through and ensure that it provides a good seal.
Step 10:
Number of downloads: 54Install the HID bulb, and secure with the retaining spring. Then slide the black plastic guard over the back of the HID bulb. Finally, put the power wires and connector inside the assembly and reattach the low beam dust cover.
Step 11:
Number of downloads: 59This shows the finished installation of the HID into the assembly
Step 12:
Number of downloads: 94This shows the difference between the HID bulb and the OEM bulb in action.
Step 13:
Number of downloads: 73This shows both HID's.
A couple of closing notes....
The actual wiring is very straight forward. Obvious male to female connections to and from the ballasts and the HID bulb. The connector on the inside of the OEM low beam dust cover that powered the OEM halogen bulb is what provides the power for the ballast. The ballasts are digital, so they can use the power from the original factory wiring.
Finding homes for the ballasts was not easy. As you know, there is not much spare room under the hoods of our Sonatas. I ended up zip tying one of the ballast to the air intake hose, and double side foam taping the other one to the top of the window washer tank.
Finally, depending on the color temp you choose for your HID, you will want to change the color of your high beam halogen bulbs so that they match in color. I had to buy cool blue H1's to come close enough in color to my HID's.
All in all, this is a great project that makes an amazing difference in both looks and safety. I can only recommend it to my brother and sister Sonata drivers!
Good luck!!! (IMG:
style_emoticons/default/thumbsup.gif)
This post has been edited by spielzeuge: Jul 1 2009, 09:39 AM
