1159=variable induction system
1191=ets limp home valve on
1193=ets limp home-low rpm
these codes dont really mean much by them selves, its just telling you that your rpms were dropping for an unknown reason. so it turned on the limp home valve so to keep the engine running. From my experience things that cause low rpms on XG's are...
sticking open egr purge control solenoid causing the egr to open when it's not supposed to
bad vacuum check valve also for the egr both witch are located on the top rear area of the intake manifold. You can try replacing both of these if you want. But this is only if your car was jerking while at a stop. IF it did it while accelerating then it would be a misfire condition. Since you did'nt say when it happens i'm gonna assume it does this while at a stop.
Hope this helps, and yes even a woman could replace these. The solenoid is held by a 10mm nut and the check valve is a just clipped on and they are connected together by vacuum lines. And they should'nt be too expensive. And I'll say this again "this is only if it acts up at idle or at a stop.
QUOTE (sureynot @ Jun 28 2009, 07:04 PM)
Hi,
My 2001 XG 300 began shaking and jerking like it was going to stop running. I took it to a local repair shop who told me it brought up these codes P115901191 and 1193 and that I would have to take the car to a dealer to find out what the codes mean.
It also needs a power steering pump.
I cannot afford an expensive repair. I have not been able to drive the car since March, and since it is my family's only vehicle, it has been quite inconvenient!
Does anyone know what these codes mean, and is it something I might be able to fix myself or without the high cost of a dealer?
I am a woman, I have no tools for working on my car. My Dad was a mechanic and I used to be able to tune up my car waaaay back in the 70's. The engine on my XG looks so strange!
Any suggestions? Thanks!
