 Hyundai-Forums.com > Hyundai Models > Azera Forum
> Determining Wire Polarity For Headlights
david r lee
post Jun 23 2009, 11:27 AM
Drives: 2008 Hyundai Azera SE
I am trying to install H11 HID lights on a H11B system. When I opened my headlight, both wires connected to the H11B Connector was yellow. Does anyone know how I can determine which wire is + or - based on the location in the connector?
I need this information to connect the wires together. I'm hoping for a solution without a multimeter...
Thank you!
andyman32
post Jun 23 2009, 04:57 PM
Expert
Drives: '96 Jaguar Vanden Plas, '99 M-B S420, '99 M-B S500
They're both yellow? One doesn't have a black stripe on it? Black stripe would be negative polarity... beyond that I think your only solution is unfortunately to test the + current with a multimeter.
You could always turn on your headlights inside the cabin, grab some bare metal somewhere on the engine or frame, then pinch each wire connector with your fingers... see which one gives you a jolt...
armoredfrog
post Jun 23 2009, 05:27 PM
Drives: 07 Azera LTD-ULT
david,
just simply hook them up and turn them on...if the polarity is correct, they'll "fire" [i.e. energize/turn-on] correctly ...if one or more doesn't reverse the polarity on the offending ballast...it's that simple...no need to get into some major convoluted procedure with a DVM/DMM, it's just not necessary in this application
...hope that helps
david-paul-1
post Jun 23 2009, 10:29 PM
Drives: 2007 Santa Fe Limited Pearl White, 2009 Volkswagen CC VR6 Sport Iron Gray Metallic
QUOTE (david r lee @ Jun 23 2009, 09:27 AM) *
Thank you!
Others have already given you "How To" advice. My advice is a bit more basic.
Anyone doing any kind of automotive electrical work must have a Multimeter.
They are cheap, and necessary. Over time, it will save you hundreds of hours and dollars in work and "Oops" costs.
You can pick one up from $15+.
David <><
This post has been edited by david-paul-1: Jun 23 2009, 10:34 PM
Stuart Loague
post Jun 23 2009, 10:50 PM
Drives: 2006 Hyundai Azera
I recently installed HIDs on my 2006 Azera limited. I had the same issue. Using a meter, I was able to detremine that the drivers side top is positive and the passenger's side top is negative. Lights work great. However, if I were you I would double-check it with a meter. David is correct in that they are somewhat cheap yet help you out a lot. Hope this helps.
No New Posts Forum Rules?
1 bucfan11 85 3rd March 2010 - 12:59 PM
Last post by: Montego
No New Posts Topic has attachmentsFor Sale Hyundai Azera Accessories For 2006 And Up
2 azeralover 84 2nd March 2010 - 11:38 AM
Last post by: azeralover
No New Posts For Sale Sonata Wind Deflector
0 azeralover 32 2nd March 2010 - 11:35 AM
No New Posts Headlights Are Always Blowing
3 bjl584 144 18th February 2010 - 04:10 PM
Last post by: lovemysantafe
No New Posts Topic has attachmentsHeadlights Won't Turn Off!
7 Spawn 133 13th February 2010 - 11:25 AM
Last post by: Spawn
11th March 2010 - 05:29 AM
Privacy Statement
