Azera Coasts Wierd |
May 24 2009, 08:58 PM
Status:
Drives: 07 hyundai azera
i never thought one of the criteria for buying a car was how it coasts. well maybe i did. i loved how my wifes grandmother's buick coasted. let off the gas and it would go for miles. this car on the other hand, when i let off the gas its fine if im over 55, but from 55 and under, the rpms fall, then rise again, then fall again, etc. its like the torque convertor locks and unlocks constantly. its such a pain in the butt and it seems to be growing in intensity. is anyone else experiencing this and more importantly, got it fixed?
Jul 27 2009, 09:56 AM
Status:
Drives: 2007 Hyundai Azera
QUOTE (jasonsazera @ May 24 2009, 08:58 PM)  i never thought one of the criteria for buying a car was how it coasts. well maybe i did. i loved how my wifes grandmother's buick coasted. let off the gas and it would go for miles. this car on the other hand, when i let off the gas its fine if im over 55, but from 55 and under, the rpms fall, then rise again, then fall again, etc. its like the torque convertor locks and unlocks constantly. its such a pain in the butt and it seems to be growing in intensity. is anyone else experiencing this and more importantly, got it fixed? I've had the same problem for several months. Not fixed yet. I'm dreading going to the dealer with this problem (see boostedfc3s' post).
Jul 27 2009, 10:00 AM
Expert
Status:
Drives: 2001 Subaru Outback & 2006 Azera Premium
QUOTE (jasonsazera @ May 24 2009, 09:58 PM)  i never thought one of the criteria for buying a car was how it coasts. well maybe i did. i loved how my wifes grandmother's buick coasted. let off the gas and it would go for miles. this car on the other hand, when i let off the gas its fine if im over 55, but from 55 and under, the rpms fall, then rise again, then fall again, etc. its like the torque convertor locks and unlocks constantly. its such a pain in the butt and it seems to be growing in intensity. is anyone else experiencing this and more importantly, got it fixed? That's how it's supposed to be! As you let off the accelerator and the speed is reduced the auto box gears down and then down again same as you would with a manual box. That's an IMPROVEMENT over the old boxes, it also provides engine braking which was absent in the older ones. All this provided you don't have cruise on (IMG: style_emoticons/default/whistling.gif)
Jul 27 2009, 10:02 AM
Status:
QUOTE (boostedfc3s @ May 24 2009, 09:33 PM)  Yes and not fixed, "everything within spec, unable to reproduce". Typical response from Hyundai service. I've heard that so many times it makes me want to punch um in the face. (IMG: style_emoticons/default/wallbash.gif) QUOTE Does it all the time. Just another reason I can't wait to get rid of the car in august. Ditto!
Jul 29 2009, 06:37 AM
Status:
Drives: 2007 Santa Fe Limited Pearl White, 2009 Volkswagen CC VR6 Sport Iron Gray Metallic
QUOTE (jasonsazera @ May 24 2009, 06:58 PM)  i never thought one of the criteria for buying a car was how it coasts. well maybe i did. i loved how my wifes grandmother's buick coasted. let off the gas and it would go for miles. this car on the other hand, when i let off the gas its fine if im over 55, but from 55 and under, the rpms fall, then rise again, then fall again, etc. its like the torque convertor locks and unlocks constantly. its such a pain in the butt and it seems to be growing in intensity. is anyone else experiencing this and more importantly, got it fixed? If I recall correctly, my 2007 Azera did the same thing and did it from the very beginning. It was even noticable when coasting at freeway speeds getting ready to hit the off ramp on level ground. I never gave it a lot of thought. I just assumed it was normal for an Azera. During the 26,000 miles that I drove the car, it never got any better or worse and I never brought it up to the dealer. David <><
Jul 29 2009, 02:00 PM
Status:
Drives: 2006 Hyundai Azera Limited
QUOTE (david-paul-1 @ Jul 29 2009, 07:37 AM)  If I recall correctly, my 2007 Azera did the same thing and did it from the very beginning. It was even noticable when coasting at freeway speeds getting ready to hit the off ramp on level ground.
David <>< I never had this problem with my 06 Azera. But I do have the cracked dash and questionable paint job. Well, it is still a Hyundai and if it wasn't for the new shocks I installed on the beast, I would be trading it in for something better, like a used Lexus LS 430.
Jul 29 2009, 07:31 PM
Expert
Status:
Drives: '96 Jaguar Vanden Plas, '99 M-B S420, '99 M-B S500
QUOTE (Qman @ Jul 28 2009, 12:31 AM)  I have this same problem, wrote about it here on this forum. Someone said that it was a feature that keeps the car from accerationg when going down hill, and it sometimes get cofused on near level gound with little resitence (drag). The car seems to do this more on shallow down hill descents and speeds below 50 mph on level ground. And No it's not down shifting, move the shifter over in 5th and it does the same with out shifting down to a lower gear. Just the RPMs change as the original post states. Mine goes up/down 200-300 rpms at speed slowing from 50-37, two to three times and remains in 5th gear. I have not taken it to the dealer and would like to know if this is what is actualy happening or somethings wrong. Does all Azera do this? Q. Yeah, whatever "it" is, all Azeras do it. They all have the same 5-speed Aisin transmission. Both of ours & my dad's do it. It's weird. At first I thought it was some kind of engine-braking feature to keep you from accelerating when coasting downhill, but sometimes it actually slows you down. Not sure what the malfunction is.
Jul 29 2009, 07:35 PM
Expert
Status:
QUOTE (petergun @ Jul 29 2009, 03:00 PM)  I never had this problem with my 06 Azera. But I do have the cracked dash and questionable paint job. Well, it is still a Hyundai and if it wasn't for the new shocks I installed on the beast, I would be trading it in for something better, like a used Lexus LS 430. LS430 looking more and more attractive all the time. They aren't pretty by any stretch of the imagination, they're just kind of... big and sharp. Nothing spectacular, but nice inside. It's almost like the equation is, "Nicest car you can get that's also reliable." It's neither THE nicest car possible, nor THE most reliable. Just a lot higher on the curve than Azera or possibly even Genesis. Oh well. I digress.
Jul 30 2009, 04:44 AM
Expert
Status:
QUOTE (campoly @ Jul 29 2009, 10:55 PM)  Did yours do "it" from the git-go. Mine didn't. Yeh, all of the three in my family had the "it" from the word go. It's sure a shame if it's not supposed to happen and new cars with only a few hundred miles on them are already having a transmission problem (or, at least, oddity).
Similar Topics
Similar Topics
