QUOTE (psu1 @ Sep 14 2009, 06:47 PM)
"On internet, there are mixed info about the bulb type; some say H11b and some say H7."
The issue is that both are correct. Before buying you need to understand which you have. Images of each are available on the net. Both are also in the manual.
Realize that H11B and H11 are not the same. I know because I made the mistake of previously purchasing Osram H7s. I kept them because they will work in the high beams.
There is one place on the net that sells a modified H11 HID kit that works in the Azera that used the H11Bs.
I replaced my H11B's with H11 HID bulbs. The difference is in the connection. The H11B connects as it's turned to fasten it in. The H11 has to be connected separately. If you do a search on HID's for H11B you can find pictures of the little plastic thing that has to be cut or broken off to let H11 bulbs turn and fasten.
