QUOTE (timfallon @ Oct 21 2009, 10:31 PM)
It will also depend on if I need special tools and ramps etc.
I've never done anything like this so it will be a **** of a ride.. and there is risk it will cost me more, but that extra cost is 'tuition on car servicing'
You'll need a jack, axle stands (safety first!), basic ratchet set, and a spring compressor (the only specialty part I think you should need.) I haven't actually looked at the back too closely, but that is the generic situation for most suspensions. The alternative is to buy a pre-assembled spring/strut assembly so you can avoid messing with the spring, but they are much more $$$.
NB: Springs are REALLY DANGEROUS. Know **** well what you are doing before doing it. If in doubt, this may be one of those projects to find someone who knows what they are doing / going to a pro shop to do it.
In addition to struts, you may want to check out other suspension parts, eg bearings to make sure everything is moving well etc. It may not be the strut at all but something that is rusted/seized.
