the refrigerant has to be checked with the correct gauge set. Again a job for a Hyundai tech, he can interface with the ECM, and check if the ECM gets the A/C-on signal. He also could check the refrigerant condition. The TCM will not select the 4th gear, if it does not see the correct signal from the range-switch. This is another item a HD-tech will be able to check in no time at all. Rather spend the money on the diagnosis, before you waist money on guess items not needed.
This post has been edited by duke: Apr 4 2005, 06:41 PM
