 Hyundai-Forums.com > Hyundai Models > Terracan Forum
> Hard To Start, hot and cold staing problem
michael von der ...
post Mar 30 2009, 08:13 AM
Drives: 2002 hyundai terracan 2.5
Hi
I drive a 2002 Terracan witha 2.5l diesel engine (56 000 km). I have trouble starting the engine and replaced the glow plugs and checked the glow relay. No check engine light is on. The car runs well otherwise. Any suggestions?
Thank you
Michael
VPOLANCOS
post Jul 14 2009, 09:49 AM
Drives: HYUNDAI TERRACAN 2002 2.5TD
hI,
I HAVE THE SAME PROBLEM.. MY TERRACAN 2002 - 2.5TDI, THE MOTOR NEVER START QUICKLY.I CHANGED ALL PART OF START MOTOR, CHECK ALL HEATER AND REPAIR THE MOTOR, BUT I CONTINUE WITH THE PROBLEM, IN COOL SOME TIME START OKEY..... BUT WHEN IT HOT WE TO START SEVERAL TIME.
IF SOMEBODY HAVE A ANSWER I WILL APRRECIATE...
BEST REGARDS,
VLADIMIR
Hyundaiownersclu...
post Jul 16 2009, 03:43 PM
Drives: Tucson
First check the cam timing /Second the valve clearances(adjust if out.)/Third the fuel pressure to the pump. Then return with your answers
michael von der ...
post Oct 8 2009, 03:34 PM
Can you get me the valve clearance and fuel pressure specs. Does the car have an electric fuel pump which feeds the injection pump?
Michael
This post has been edited by michael von der burg: Oct 8 2009, 03:36 PM
Robert B.
post Oct 8 2009, 04:06 PM
Drives: 2004 Terracan 2.9 CDRi, 2008 Getz 1.6
Heres the valve clearance information.
Attached File  Terracan_2.5_VALVE_CLEARANCE.pdf ( 105.34K ) Number of downloads: 2
Apparently, there is no electric fuel pump on the diesel terracans (2.5 or 2.9), but there are plenty of things that can give you a hard start.
Attached File  TERRACAN_2.5_TROUBLESHOOTING.pdf ( 248.42K ) Number of downloads: 4
Have you scanned your vehicle? Error codes?
Robert B
michael von der ...
post Oct 9 2009, 03:06 PM
Hi Robert
thank you for your input. I did hook up a scanner but found no codes. I live in Canada but the car is used in the Dom Rep (just like Vladimir's). It has a new battery, the glow system works good and with under 60 000 km the compression should be fine. It starts cold better then warm and runs otherwise great. I wonder if the poor diesel quality in the Dom Rep is the cause. I will check the valve clearance as soon I get back to Puertp Plata.
It always starts with a second battery hooked up to it what let me first to believe that the starter does not turn fast enough. I rebuilt the starter (it looked perfect) and the problem is still the same. I was considering using a second battery and running only the starter on 24 Volt. What do you think?
Michael
Robert B.
post Oct 10 2009, 12:12 PM
QUOTE (michael von der burg @ Oct 9 2009, 03:06 PM) *
Hi Robert
Michael
I would pay a closer look to your rebuilt starter. Just by "feeling", do you feel your starter (with a single battery) is spinning the engine fast enough to start, or does it feel lazy and muggy, like your battery is half dead?
Now, OTOH, do you hook up de second battery in parallel or in series? Parallel is + with + and -with- to have 12V with double the amps. Series is +with- in series, to have 24V with same amps.
If hooking up second battery in parallel, I would suspect your main new battery is either too small or not good (its not the first time a new battery goes bad). If hooking up in series, then I suspect there is something wrong with the starter motor. Not spinning fast enough?.
Maybe you can get a shop that can switch starter motors for a test, or even you can switch batteries and test them.
Robert B
michael von der ...
post Oct 12 2009, 10:26 AM
It is a gear reduction starter and seems to turn pretty slow. I will get back to The Dom Rep in January and will work on the beast. I hope we will in touch then .
Thank you for all your help
Ciao
Michael
No New Posts Topic has attachmentsTo All Complaining About Hyundai Copying Styles...
7 mamamia 315 18th November 2009 - 12:29 PM
Last post by: JohnIrvine1
No New Posts Top Dead Center And Timing
2001 Tiburon
4 duane84 71 11th November 2009 - 10:05 AM
Last post by: duane84
No New Posts Tokico Shocks
Let's Hit them up
15 PastorK 195 10th November 2009 - 05:27 PM
Last post by: teevee247
No New Posts Starting Trouble
2 dyxlexic 134 7th November 2009 - 05:30 PM
Last post by: dyxlexic
No New Posts Top 20 Most Dangerous Cars
21 wizzzer 4,833 1st November 2009 - 12:21 PM
Last post by: crug75hid
21st November 2009 - 05:41 AM
Privacy Statement
