this is probably a security code that has been entered incorrectly. You may have to take the stereo to your local garage to see if they can reset it.
You might be able to reset it yourself by putting the stereo head unit in the fridge for about 5 hours, take it out, leaving it somewhere warm for a few hours to clear any condensation inside (or it may well blow when you plug it back in). Then put it back in the car and it should hopefully have reset the security code ... only problem is, you now need to find the security code - so have a look in it's manual (if it has one).
Or I could be completely wrong and it could just be an error code - have you tried looking at the manufacturers website?
