 Hyundai-Forums.com > Hyundai Models > Elantra & Lantra Forum > 3G (2001-2006) Elantra
> Clutch Out Of Adjustment!, Please help me out!!!
bankston2207
post Mar 27 2005, 02:57 PM
Drives: 2001 Hyundai Elantra GLS
[FONT=Arial][SIZE=7][COLOR=gray]
I just Purhased a 2001 Elantra and the clutch is out of adjustment. When I let out on the clutch I have to give the car some gas or it will stall. I know where the clutch mechanism is but does anyone know how to adjust it?? Please let me know.
Dr. Hundi
post Mar 27 2005, 06:05 PM
Group: Mod Emeritus
Drives: Cressida
You will have to specify exactly what the problem is.
If you engage the clutch with no rpm, then the engine is supposed to stall.
If you let the clutch out with no rpm whilst it is in gear and it slips, then you have a major problem.
Please specify, or even give an example then we will help.
bankston2207
post Mar 27 2005, 07:43 PM
The clutch does not slip The only problem is taking off in first gear. It seems that you have to ride the clutch a little more than normal. After first gear everything is fine. I think that the clutch just needs to be adjusted a little.
VALKYRIE YB70
post Mar 29 2005, 12:13 AM
Mod Emeritus
Drives: Modified (180 b.h.p.) `95 Hyundai S-Coupe Turbo SE ....Sadly now sold & replaced with an `04 Alfa Romeo 156 2-litre Veloce! :-http://aol.photobox.co.uk/album/thumbnails.html?c_album=7089276&page=all
It`s a hydraulic clutch.......the only `adjustment` is really to bleed the system of any air bubbles.
Nick.
gordo
post Mar 30 2005, 11:40 AM
Super Member
Drives: 2002 Elantra
This really doesn't sound like a clutch problem
With a bad clutch you would normally expect to have slipping (excessive wear) or trouble shifting into 1st or reverse (The clutch plate is coming apart and not fully disengaging)
If you have to ride the clutch to get moving, it could mean that the engine is not developing enough power at low rpms to get the car moving.
bankston2207
post Apr 1 2005, 05:51 PM
ok... i think you are right. the engine problebly is not having enough power to get the car moving at low rpm. so... how do i fix this problem?
gordo
post Apr 1 2005, 06:29 PM
Super Member
Unfortunately it could be a lot of things - from the ignition timing being off to a faulty knock sensor. It could even be something as simple as a dirty air filter.
But since the car seems to be running well otherwise I wouldn't expect it would be anything too serious.
I think your best bet would be to take it to a Hyundai dealer or someone who can use a scanner to pull the data codes - it takes about two minutes.
The two-litre engine normally produces quite a bit of low-end torque - enough that on a level surface you should be able to get the car moving without using the gas pedal at all.
Thats just my take - otheres on the board are sure to have some better ideas.
No New Posts Clutch Parts For 03 Gt V6 Tiburon
Looking to sell
4 jokerZwild 49 13th November 2008 - 01:12 PM
Last post by: jokerZwild
No New Posts Clutch Related Problem
Bad ride
1 wishlist 51 9th November 2008 - 09:04 AM
Last post by: Itsatusconmatey
No New Posts Topic has attachmentsOff Topic But...read Please!
found 2 baby mice in my living room
16 AFireryAccent 244 5th November 2008 - 12:34 PM
Last post by: craigbrooks
No New Posts Clutch Or Tranny Or Both
SCRAPING NOISE WHEN I STEP ON THE CLUTCH
3 PLONDAR 92 29th October 2008 - 11:29 AM
Last post by: byronguidry3732
No New Posts Off To The Track Tonight
18 v33sonata 271 13th October 2008 - 04:30 AM
Last post by: kyhwa777
2nd December 2008 - 06:54 AM
