> Help!, oil burning
mozz24
post Mar 25 2005, 07:44 AM
Drives: modded accent 98
hi i have a 98 accent 1.5 mvi
i have a slam problem with it burnin oil /or i think it is/
it done 84000 miles and every 2 week i have to put 2 ltrs of oil in the back end is covered in black from the ex, dose anyone know what is wrong with it?
can anyone help ?
also i have hread that a head and turbo off a 1.5 coupe will fit is this true?
thanks
duke
post Mar 25 2005, 05:28 PM
Community Advisor
Group: Community Advisor
Drives: 2007 NF Sonata 2.4L
how many miles per liter ?????????
get a can of WYNN's engine flush, add it to the engine oil, run engine at +-1500 rpm for 20 minutes, then doe oil & filter change. This will clean the engine interior, remove carbon build up from the piston rings (so that they can open again, and block the oil from entering the combustion chamber), and clean the hydraulic lifters.
VALKYRIE YB70
post Mar 26 2005, 05:27 PM
Mod Emeritus
Drives: Modified (180 b.h.p.) `95 Hyundai S-Coupe Turbo SE ....Sadly now sold & replaced with an `04 Alfa Romeo 156 2-litre Veloce! :-http://aol.photobox.co.uk/album/thumbnails.html?c_album=7089276&page=all
Hi!.......what Duke suggests is correct, try this first & use Castrol High Mileage 15W/40 oil.......also replace the PCV valve (on the back of the rocker cover).
If this doesn`t reduce your oil consumption, you may get lucky & find new valve stem seals does the trick. Failing that, it`s new piston rings!.
Forget about turbocharging a normally aspirated 1.5 SOHC Alpha motor with 84K miles.......you`ll blow it to pieces!.
The Scoupe Turbo`s engine has many internal modifications to enable it to cope with forced induction from the factory, yet your motor is far from new!.
Nick.
No New Posts Topic has attachmentsPlease Help! Who Knows How To Disassemle Gearbox Trajet 2.0 Crdi 2001
gearbox Trajet 2.0 CRDi 2001
3 bum71 19 Yesterday, 05:06 PM
Last post by: Hyundaiownersclub
0 bum71 13 17th November 2008 - 04:22 PM
Last post by: bum71
No New Posts Topic has attachmentsHelp! Hitch Weldnut Missing!
Trying to install hitch. One hole biggr
8 dbldwn02 341 15th November 2008 - 10:43 PM
Last post by: dbldwn02
No New Posts Please Help! (2004 Elantra Crankshaft Sensor)
14 badkid32 270 11th November 2008 - 05:18 AM
Last post by: badkid32
No New Posts 1997 Elantra - Code P0455 - Help!
Pulling a P0455 code. How do I fix it?
7 sithlord 423 8th November 2008 - 09:09 PM
Last post by: sithlord
21st November 2008 - 01:30 AM
