I thought I would post this HOWTO on changing the oil in a Vera Cruz. I was unable to find this info online with images
and thought it would be helpful to the community.
The Subject:
Our 2008 Limited Vera Cruz with 4034 Miles.
(IMG:
http://i281.photobucket.com/albums/kk228/seanp1031/VeraCruz/DSCN2788.jpg)
(IMG:
http://i281.photobucket.com/albums/kk228/seanp1031/VeraCruz/Oil%20Change/DSCN3015.jpg)
Here's what you'll need to change the oil:
Oil Filter with two o-rings ( Purolator Model L35610)
6+ quarts of Oil ( I used Fully Synthetic 10w30 Mobil 1)
10mm socket(for the engine cover bolts)
17mm socket(for the oil drain plug)
Drain Pan
Funnel
(IMG:
http://i281.photobucket.com/albums/kk228/seanp1031/VeraCruz/Oil%20Change/DSCN3022.jpg)
1. Pop the hood and use the 10mm socket and ratchet to remove the 6 engine cover bolts. Remove the engine cover and set it aside.
(IMG:
http://i281.photobucket.com/albums/kk228/seanp1031/VeraCruz/Oil%20Change/DSCN3017-1.jpg)
2. Dust off the top of the engine and surrounding areas. I used an old clean rag because I didn't feel like busting out the air compressor that
is stored in my shed. This should lessen the chance of dirt or debris entering the engine via the oil fill cap or the filter housing.
3. Locate the filter housing. It is on the right side of the engine as you are facing the engine bay.
(IMG:
http://i281.photobucket.com/albums/kk228/seanp1031/VeraCruz/Oil%20Change/DSCN3018-1.jpg)
4. Using your strong hand, twist the cap on the filter counter-clockwise to remove. There will be some residual oil on the cap and insert.
I had a plastic container ready to place the filter cap into so as not to drip on the engine. Set this to the side for the moment.
(IMG:
http://i281.photobucket.com/albums/kk228/seanp1031/VeraCruz/Oil%20Change/DSCN3023.jpg)
5. Losen the oil fill cap near the front of the engine. This will reduce the vaccuum and let the oil drain more freely.
6. Slide the oil drain pain under the front of the vehicle and grab your 17mm socket and ratchet and slide under the front of the vehicle.
The drain plug is on the right rear bottom side of the engine and is black in color. Remove it and let the oil drain.
(IMG:
http://i281.photobucket.com/albums/kk228/seanp1031/VeraCruz/Oil%20Change/DSCN3021-1.jpg)
7. While that is ocurring, break out the new filter and o-rings. Replace the o-rings on the filter cap. There is a small and a large o-ring.
(IMG:
http://i281.photobucket.com/albums/kk228/seanp1031/VeraCruz/Oil%20Change/DSCN3025.jpg)
(IMG:
http://i281.photobucket.com/albums/kk228/seanp1031/VeraCruz/Oil%20Change/DSCN3026-1.jpg)
7. Insert the new filter into the housing making sure that it seats down all the way.
(IMG:
http://i281.photobucket.com/albums/kk228/seanp1031/VeraCruz/Oil%20Change/DSCN3027.jpg)
8. Replace the filter cap and tighten firmly.
9. Check the oil drain pan. If the oil has drained to your liking, replace the drain plug and tighten to 32.5 Ft Lbs.
(IMG:
http://i281.photobucket.com/albums/kk228/seanp1031/VeraCruz/Oil%20Change/DSCN3029.jpg)
10. Hold a funnel over the oil fill hole and gracefully pour oil. I put in 5 quarts and the dipstick barely registered "low".
I ran the engine for a minute or so and then checked the dipstick again. It stil registered "low". I added another quart
which brought it to the "full" mark.
11. Replace the engine cover and be sure to tighten all 6 bolts.
Please let me know what you think of my HOWTO.
