my suggestion for you is that don't waste your time on searching your solution on these forums.just went to the dealership and he will definately solve your problem.
I think you exactly are not from Australia...so it"ll be difficult to you to search the dealership.
Just try once....still if i"ll get any solution for your problem i"ll post to you...
bye
QUOTE(recon @ Jul 27 2004, 02:11 PM)
I bought in September an old 2000 Hyundai Trajet GL to travel around Australia. I have a few problems with it:
I had to change twice the contact set, which was very used each time.
Is it because of the condenser? the battery?
Whan can I do to fix this problem? :unsure:
[right][snapback]436[/snapback][/right]
