fi you did continues braking on & off, then yes they get warm. the other side may not brake as well. did you fit "silver anti seize compout" to the pad to carrier contact points ?? What is the miliage ?? here is someting else to look out for, if the hand brake is not correctly adjusted, then the rear brakes will not properly self adjust. This can lead to early pad wear and disc warpage. here is what to do First, you loosen that center nut from the h-brake handle main cable(under the center console at its rear end), until there is a tiny bit of play between the nut and the "YOKE". Then you adjust the rear brake shoes brakes. For this, you have to remove the wheels & drums. << OR >>, You let rear brakes do it themselves. Now, since the rear "SELF ADJUSTERS" are in the proper position (due to the fact, that the h-brake free-play has been established), they will adjust the rear brakes bit-by-bit every time you apply the brakes. At the beginning, you may notice that the pedal may be too low, but it will come up more & more after each brake application. Once the brake is fully “SELF ADJUSTED” (which won’t take too long), you will never need to adjust the foot or hand brake again. A correctly adjusted h-brake must have 6 to 9 notches when pulled.
