Low Idle Speed At Start Up |
Dec 19 2008, 03:56 AM
Status:
Drives: terracan 2.9crtd 2005 manual
Thanks montego. The problem isnt specifically when the engine is cold. It did it 5 times on wednesday (throuhout the day) but has been fine since, including this morning, when it was very cold. I am a bit worried as i have heard about problems with the fuel pumps and hope it isnt the start of something serious. The car drives normally and starts normally for most of the time, and no warning lights have come on, so i am hoping its not anything to do with the fuel pump. The coolant temp reading seems fine (it stays at just under half on the gauge once warm). Anybody got any other ideas? (IMG: style_emoticons/default/sad.gif)
Dec 19 2008, 01:06 PM
Status:
Drives: Tucson
QUOTE (porky @ Dec 19 2008, 08:56 AM)  Thanks montego. The problem isnt specifically when the engine is cold. It did it 5 times on wednesday (throuhout the day) but has been fine since, including this morning, when it was very cold. I am a bit worried as i have heard about problems with the fuel pumps and hope it isnt the start of something serious. The car drives normally and starts normally for most of the time, and no warning lights have come on, so i am hoping its not anything to do with the fuel pump. The coolant temp reading seems fine (it stays at just under half on the gauge once warm). Anybody got any other ideas? (IMG: style_emoticons/default/sad.gif) Your dealer should take some live data readings and send them to Hyundai Technical. Its not just a case of code reading these days.
Dec 19 2008, 02:04 PM
Status:
Thanks HOC, I will ask them to do that if they cant find any fault. (IMG: style_emoticons/default/thumbsup.gif) Would you have any idea what it could be?
Dec 19 2008, 05:06 PM
Status:
Drives: Tucson
QUOTE (porky @ Dec 19 2008, 07:04 PM)  Thanks HOC, I will ask them to do that if they cant find any fault. (IMG: style_emoticons/default/thumbsup.gif) Would you have any idea what it could be? Unfortunately not. Brake switch/Mass Air Flow/Fuel Pump,even an injector but its just a guess
Dec 30 2008, 05:22 PM
Status:
Drives: Terracan Highlander 2.9 Crdi Manual
I had an intermitent idle problem with mine as well (2005 CRDi manual), only thing was that it would go from 800rpm up to 1000 rpm for no apparent reason. The problem then became constant, but if you just touched to brake pedal so the brake lights came on the idle would drop back down to 800rpm.
The final solution was to replace a faulty knock sensor. Once again no fault codes showed up, but one other vehicle here in Oz had had a similar problem and it was found on the Hyundai dealers forum site.
My knock sensor may have failed in full advance and yours might have failed in fully retarded (just a guess).
This post has been edited by BJL: Dec 30 2008, 05:23 PM
Jan 1 2009, 07:41 AM
Status:
Thanks BJL, I will mention that to dealer if it plays p again. It is fine at the moment (IMG: style_emoticons/default/57.gif) Happy New Year !
Feb 3 2009, 05:05 AM
Status:
Update: the tcan has not done it again since last post. dealer found nothing wrong/no fault codes. (IMG: style_emoticons/default/smile.gif)
Feb 13 2009, 11:14 AM
Status:
Sorry jeff, i am a fair way from cardigan, but know plenty of sheep farmers (IMG: style_emoticons/default/whistling.gif)
Apr 27 2009, 07:04 PM
Status:
There was a survey done by the Terracan forum in Oz and out of 49 respondants 5 had suffered a pump failure. There seems no real trend to the failure other than they may occur a short time after the fuel filter is replaced if the fuel system is not primed properly and the pump operates dry for a short period of time. I think all fuel pump failures have also required the entire fuel system to be replace due to metal from the failing pump going through the injectors and fuel lines. You can check this subject on the Oz forum at http://forum.australia4wd.com/index.php?sh...mp;#entry116358
Apr 30 2009, 01:31 PM
Status:
The plot thickens. The 'can failed to start again today, but this time the glow plug indicator did not illuminate!!! Left it for 5 minutes and the car started perfectly! (IMG: style_emoticons/default/unsure.gif) This is looking more and more like an electrical gremlin to me. The trouble is unless the fault shows up in dealer they cant diagnose any faults! (IMG: style_emoticons/default/rant2.gif) I would be grateful for any help!! (IMG: style_emoticons/default/57.gif)
May 14 2009, 12:08 PM
Status:
Update! Had the 'can back from dealers today. The problem was a faulty rail pressure sensor. This involved changing the whole common rail and fuel pipes. It eventually showed up as a fault code. I hope this helps anyone with a similar problem! Its great to have the beast back after 4 days with a 3 door suzuki swift (IMG: style_emoticons/default/wacko.gif) Thanks to everyone who helped (IMG: style_emoticons/default/thumbsup.gif)
Similar Topics
Similar Topics
