QUOTE (rendezvous65 @ Feb 23 2009, 02:27 PM)
Still no update from mapnsoft.com in regards to the Genesis. Maybe it will come out later. Hyundai might have chosen someone else to resell the maps for the DIS. The DIS controls the navi, HVAC, backup camera, AV, and Automotive stuff through a control knob. Only the tech package gets the DIS. DIS Map updates would be done by DVD. Harman Becker Automotive system is the OEM for the DIS not LG.
Called Mapnsoft yesterday and an update is in the works. You get it on a DVD and it will download the data to the DIS. It should take about an hour to update the maps. No word if it reloads the software. She said it will have a security code so you can't use it on another Genesis. This makes it harder to pirate. For all you Genesis owners you should get something in the mail reminding you about this update. I believe the update can be done at home and not a dealer since it requires you to enter a ID to get the security code. Hope this helps in regards for map updates.
