Leaking Sunroof!, Sunroof leaks
| Tucson77 |
Mar 11 2005, 10:42 AM
Drives: 2005 Hyundai Tucson Status: OFFLINE
[FONT=Arial][SIZE=1]I have a severe leakage issue with my Tucson's sunroof. I was hoping some of the contributors to this forum could check their vehicle's sun-roofs the next time they're going through a car-wash or parked near their garden hose at home. You really need to inspect the sun-roof for these leaks as it doesn't actually drip into the interior of the car, but rather silently into the drip channel/tray under the seals. Incredibly, the dealership's claiming that this is perfectly normal and that all sunroofs leak profusely, stating that the drip channels are designed to accommodate these new style of "leaking sunroofs" ..... I've never had a sunroof leak in any other car, including my Hyundai Elantra. It's dripping along the entire back seal.... and at quite a rate. I first noticed it while going through a car wash and again when testing it with a garden hose (not high pressured) at home. The same thing happens when it's raining hard. I took it to the dealership where I purchased it. On the 1st visit they stated that indeed there must be a problem as it was not normal for a sunroof to leak at all. They made some adjustments and claimed they had fixed it. I took it through another car-wash and it still leaked. I called them back and the tech stated that a really high powered carwash might force a small amount of water under the seals, but that if I tested it with a garden hose it should be fine .... So I tested with a garden hose, gently pouring water on the roof - and it still leaked. So I took it back again ... Unbelievably, the dealership is now claiming that this is actually a perfectly normal behavior for the Tucson's sunroof and that it was actually designed by Hyundai to leak a little bit and that that was what the drip channels were actually for ...... "Normal leakage". They called me over to the side of a building where they had another new Tucson parked and showed me that when they poured water over it with a hose, it too leaked (which it did - and it was literally pouring into the drip channels ....) Either they staged this demonstration for my benefit by compromising this other sunroof, or, Tucsons in general have a very serious design flaw with their sunroofs. I would greatly appreciate your comments, observations etc ...
| new car junkie |
Mar 11 2005, 02:02 PM
Drives: new hyundai tuscon 2.0crd auto Status: OFFLINE
:o With my previous V6 coupe/tib' water would pour thru the rear hatch gasket and on to the rear leather seats. On my new Tucson the car wash broke the rear wiper arm right thru the spindle arm, and Hyundai will replace it f.o.c.Although it was not classed as a "component failure". But i have to say no water leaks on my sunroof,...........yet.
The only thing that did get my attention was that the plastic trim sheild on the wind deflector flew down the highway yesterday,still the roof works better without it.The dealer said it was probably some plastic "transit cover" that should have been removed on PDI.
| grimfish |
Mar 14 2005, 03:03 AM
Drives: 2005 Hyundai Tucson Elite Status: OFFLINE
QUOTE(new car junkie @ Mar 12 2005, 05:02 AM) The only thing that did get my attention was that the plastic trim sheild on the wind deflector flew down the highway yesterday,still the roof works better without it.The dealer said it was probably some plastic "transit cover" that should have been removed on PDI. This was just a small film of plastic shielding (like what you get on new Stainless Steel items liek ovens and sinks) that covers the wind deflector bar that pops up when the sunroof is opened. I too had to take mine off when I got home from the dealer (I'm 6'5" so I could see it with the sunroof open easier than most would). It's nothing to worry about at all. :) Oh and no problems with mine either, I hope you can get it fixed. This post has been edited by grimfish: Mar 14 2005, 03:06 AM
| normbar |
Apr 4 2005, 06:07 AM
Drives: Tuscon Status: OFFLINE
Hi All
I had a bad leak from the sunroof.
My daughter first noticed splashes of water on the rear seat, on closer inspection I noticed wet carpets and a wet patch by the rear window air bag. It got really bad when the car was washed, with a couple of inches of water in the spare wheel well.
Dealer spent a few hours finding it but when they did find it the said it hadn't been fitted at the factory correctly.
Been fixed for about 2 months with no more leaks.
hope this helps
Normbar
| Highlander |
Sep 27 2005, 06:54 AM
Drives: 2004Hyundai Tucson 2.7 Elite Status: OFFLINE
no probs with the sunroof,maybe we are have received a better batch in Australia. :thumbsup:
| cyninmn |
Aug 21 2006, 05:43 PM
Drives: 2005 Hyundai Tucson LX Status: OFFLINE
My 2005 Tucson has gone through a few car washes and never did I have what happened in the past two rain storms while out driving. The water from this famous "open" style roof with drains - leaked into my vehicle, dripping through the header slide panel - soaking it for over 2 inches across it's entire width. When I took it in - in the middle of the rain storm - they handed it back to me and told me not to put the hand towel in, because the tray would drain itself. OMG. To add insult to injury it was handed back to me with oil and mud all over my seats and door panels. I scheduled a warranty appointment. They took it out and put it back in and could find nothing wrong with it. They handed me the keys back and said they'd "blown" out the lines, just in case. I had to ask for the part to be ordered to have my water stained header panel to be replaced - that was two weeks ago - haven't heard from them. Water was literally RUNNING into my vehicle and hitting the driver/passenger arm rest. This is not normal for any vehicle I've owned. I love my Tucson but I think the people who do service on them in the Twin Cities MN area just do NOT get it. Good luck to everyone else, I can't wait to see it rain again and go out driving and see if it's still overflowing it's boundaries in the rain - again, never did it in a car wash... Strange.
| ZA_Tucson |
Oct 22 2006, 03:07 AM
Drives: 2006 Hyundai Tucson 2.7 V6 GLS Status: OFFLINE
Hi all,
After my Tucson was +/- 6 months old, I also noticed water (not too much) dripping from the rear part of the sunroof. After my first visit to Hyundai, they found that there was a +/- 1mm blue plastic strip over one of the front seals. This, they say, should have been removed with the PDI. Ok, happy with that. Short while later, the water leak started again. During the second visit, I was told that there is actally a technical note released on this, that stated that the sunroof be replaced with a new version that apparently doesn't open a far as the old one. I think the new s'roof will stop about 50mm short. They say that the old s'roof opened to far causing one of the rear seals to 'fold' causing a leak. I can buy into this. The tech note is dated 06 September 2006 so it's fairly recent. I'm now waiting for the new unit to arrive, should be installed in the next month or so together with the 15K service.
Any other South-African members having the same problem ?
Will keep you posted.
06-April-2007: Ok, the new unit has been fitted, but it's still leaking. The symptoms are exactly as what Tucson77 had. No water (that I know off) is getting into the vehicle. I'm worried about rust accumulating somewhere in the roof. The vehicle is going back again this week, so let's see what happens.
This post has been edited by ZA_Tucson: Apr 6 2007, 08:08 AM
| enigma |
Nov 20 2006, 02:24 PM
Drives: 2006Hyundai Tucsin LX Status: OFFLINE
I have a Lexus with sunroof. It is a very bad experience to find that water drip into the car from outside rain or wash. Dealers just gave me the normal stuff, i.e. they are going to investigate and they will charge me each hour of labor.
My wife said to me perhaps it is the sunroof drain hole that has been obstructed or blocked. I got a piece of wire and started to pocket the drain holes and since then no more water into the car.
When I bought my Tucson I ordered it without sunroof because my past experience.
| kitkatjeff |
May 28 2008, 01:10 PM
Drives: 2000 hyundai accent 1343 Status: OFFLINE
my wife has an accent 1.3i with a sunroof, 2000 model. Every time it rained she got soaked due to water pouring in all round the sunroof. I used some duct tape to seal the sunroof off till l had more time to sort the seal out. Next time it rained she got soaked again. I had a look and removed the rubber strips where the joint line between the roof panel and the body is. The two rubber strips on the roof. I then used a mastic gun and some clear silicone and resealed the joint line and then clipped the rubbers back in place. Touch wood, and we have had plenty of rain, the car has not leaked since. Hope this helps anyone else with the same problem.
| rxc |
Jun 4 2008, 07:59 AM
Drives: Hyundai Tuson GLS 4 WHD Status: OFFLINE
I am experiencing the same issues on my 07 Tuscon as Tucson77 posted. We are not getting a pouring of water but there is definitely an accumulation of water on the drip tray after a moderate rainfall or through a car wash. We first noticed the problem when only have the car serval weeks, my wife took it through a car wash and water splashed her in the face. I have contacted corporate who has put me in touch with the regional agent who covers our area. We've had our Tucson brough in 3 times to the dealership and we also brought it 1 time to a separte dealership. The issue is not resolved and we are constantly getting the same response that this is the design of the vehicle and it will never be 100% no leakage. We also have an apparent whistling noise coming from the sunroof because the seal is not fully tight. We experience this when the vehicle is at high speeds.
I see no mention of this so called "normal leakage" anywhere in the owners manual nor was this mentioned during the purchasing process. I am at my wits end with this issue. I do not believe there response is in truth. I can tell you that the tray and drain holes are a back-up system only designed for an instance where the sunroof fails, the water will catch on the drip tray and drain into the holes.
I am very concerned about rust and the headliner in the future.
I'm not sure where to take it from here. I see this is an issue with other Tuscon's and I believe this is a design issue and the dealers will not be able to fix it.
| rxc |
Jun 26 2008, 10:04 AM
Has anyone had any resolution with their leaking sunroof?? They insist that this is the design. With that being the case, the drip tray would take the place of what the seal is designed for (not let water through). That doesn't seem logical. I've talked to mechanics as well who say a sunroof should not leak as a fuctional design.
| rxc |
Jul 1 2008, 11:39 AM
Thank you for the advise. I have written several letters to corporate and I have had no solution. They insist this is how it is designed. My case manager told me that Hyundai stands behind these statements and my only options are to get a lawyer. I'm not backing down and I thank you for you support. At least I know I'm not crazy!
I will write a letter to the CEO (I'm assuming I can find his name on the website)
Anyone else reading this who is having the same issue can jointly, with me, file a class action lawsuit.
I will you updated.
Track this topic
Subscribe to this forum
Download / Print this Topic
Link To Us
Similar Threads
Similar Threads
11th October 2008 - 09:06 PM |
