Michelin Slowly Leaking Air, Front Driver's Side tire is leaking air |
Oct 12 2008, 09:18 PM
Status:
Drives: 2007 Hyundai Azera
I have a 2007 Azera Limited with about 13,500 miles on it.
The past few weeks I have noticed that my front driver's side tire seems to be leaking air at the rate of about 1-2psi per day.
It has happened thrice now in the past month. I keep my tires inflated to 35psi. However, this front driver's side tire loses about 7-8 psi every week & sets off the TPMS. All the other tires lose maybe about 1-2 a month. (I check them monthly)
Now, there are 3 possible reasons. A nail or some minor tear on the tire. The other reason might be a faulty Metal Valve Stem or the tire rim.
If it turns out to be a problem with the valve stem or the rim, would it be covered by the warranty? Would the warranty be Hyundai's or Michelins?
This post has been edited by wobbly_ears: Oct 12 2008, 09:22 PM
Oct 13 2008, 09:15 AM
Status:
Hey, thanks guys! I'm planning to take it to a local tire shop near work today. Or, do you think I am better pff taking it to the dealer?
The reason I'm asking this question is that with the recent reports on recall of Chinese made generic valve stems & the fact that it has TPMS? Also, since there are so few Azzys on the road here, would hey have OEM metal valves at my local Firestone or NTB?
Oct 14 2008, 11:52 PM
Status:
You guys were right on target. It was a small nail right on the sidewall. Probably one of the remnants from Hurricane Ike. (I have been driving in areas in Houston where the fences are still down)
Went to NTB to get a new Michelin & my heart almost jumped to my mouth when I looked at the price!
$180 later, I was out on a new tire at 13800 miles.
Sigh. **** you Hyundai for choosing a really expensive OEM tire...
Nov 18 2008, 01:37 PM
Status:
Location: Murrieta, in Riverside County, Southern Kaullifornieia, USA
Drives: 2007 Azera SE Limited, build date 12-12-2006, and 'Old Faithful,' our Kona Ford Focus
(IMG: style_emoticons/default/puzzled.gif) So the question follows: What are you doing for a replacement tire?Your TPMS should activate your dash indicator at any psi below 25 lbs. Another trip to the stealership? BTW, don't give up on the factory rep idea. Keep putting the screws to Hyundai and perhaps, just maybe, the higher ups will get the message and develop a better replacement shock. (IMG: style_emoticons/default/whistling.gif) Delfin
Nov 18 2008, 09:02 PM
Expert
Status:
Drives: 07 Azera Ultimate #1, 07 Azera Ultimate #2, 96 Vanden Plas, 97 XJR
Yeah slow leak is almost always a nail, but I have put patches into tires... I don't know why you wouldn't, you have to get the tire off the car and it takes a bit of elbow grease, but ultimately, it works, the tires don't leak. I'm thinking of a set of 10-year-old tires I had on a low mileage Taurus we sold early last year. The tread was getting somewhat low (52k miles) so it kept picking things up... from where, I know not. It simply had a propensity for finding sharp metal refuse. I had 3 patches in one front tire and 2 in the other, and they were just fine. Replaced the tires before selling because of the tread, not the patches.
You only replaced one tire? Hmm...
Nov 18 2008, 09:06 PM
Expert
Status:
QUOTE (IHOTI @ Nov 17 2008, 11:06 AM)  you probably have a nail in the tire, i had a nail in mine for about 5 months brought my car in for oilchanges and balance and another time for 30k service and the **** techs didnt even tell me i had a nail i mean they rotated and balanced all the tires how could they of not spotted the nail ? it kind of got me worried to the point where if i dont ask for the tech to look for something they wont tell you its wrong... =\ I wouldn't fault them for it, even a nail with a big flat head can be hard to spot in the tread - a small nail will almost disappear into the rubber. The only way to find it is if you know there's a problem, an air leak. Usually I take off the wheel, hose it off, then spray it all around with a spray bottle with a bunch of dish soap and water, shaken well. It starts to foam around the leak. Out of maybe a dozen nails and screws I have pulled out of tires on my cars, I would have been able to see only 1 or 2 without the soapy water, and even at that, there's NO way I would have noticed them without being aware of a problem, an air leak, that would prompt me to look for it.
Similar Topics
Similar Topics
