> Brakes Squeeling <1yr
g3mini
post Oct 12 2008, 12:08 PM
Drives: 2007 Accent
hi
i bought my 2007 accent in dec 2007.
i have noticed that the brakes are starting to squeel/squeek when i am stopped (not all the time but it does happen). it this normal for a new car in less than a year for this to happen? what is causing it?
is this something covered under warranty? i just can't believe they'd already be worn (almost 20,000kms on it now). actually i can since i got a lemon to begin with, but the brakes haven't even been inspected yet in the regular maintenance schedule...it's coming up.
should i tell them about it before the year is up?
hyunnychub
post Oct 12 2008, 05:03 PM
Drives: 2007 Accent 3 door 5 speed
your well beyound the adjustment part of the warranty so if the brakes are gone, you'll have to pay for them.
it's more than likely just dirt on your brake rotors.
i woulnt worry about it unless it's constant...
btw, what's making you think your Accent's a lemon?
I have 26,000 kms on mine and it's been flawless minus the defective tire which really inst hyundai's fault anyways.
This post has been edited by hyunnychub: Oct 12 2008, 05:06 PM
g3mini
post Oct 12 2008, 07:05 PM
Drives: 2007 Accent
since i bought the car i have had a problem when i go to excelerate. the car quite often bangs into gear, like a harsh shift, usually from second into third. it's an automatic. i have gone to two dealerships and BOTH told me it's 'normal' and one service manager even told me that the car doesn't know what gear to put it in and so is knocking it down two gears and hence the bang...and this is supposedly 'normal' for hyundais. LMAO! So he refused to fix something that is normal. i took other accents out for test drives and they did not (of course) do this.
i have FINALLY found a dealership and technician that acknowledge that there is something wrong with my car and that this is not normal. so we are now in the beginning process of trying to figure out what is wrong. next week they are going to reset the computer and see if it has something to do with the adaptive learning (although i doubt it). hyundai canada suggested this be done first, so whatever.
i can not believe it's taken me a year and three dealerships to get this acknowledged!
i'm gonna give my tech a big box of chocolates when my car is fixed and a hug, that's for sure!!!
thanks for the info about the brakes. i hope that's all it is. i shouldn't need NEW brakes after a year....
This post has been edited by g3mini: Oct 12 2008, 07:06 PM
hyunnychub
post Oct 12 2008, 07:18 PM
thats a f in drag man
im really leary on hyundais automatics...
id stck to 5pd in the accent.
just keep your cool, i know it's hard but make sure you do.
you get more ants with sugar than vinegar....
let us know what happens...
Naitomea_Neko
post Oct 12 2008, 09:28 PM
Drives: 2007 Hyundai Accent GS
You definetly shouldn't need new brakes after a year....unless you are doing some serious braking. Which I don't think you are.
I've had mine for 2 years and the brakes are just now starting to squeal, but that's because of road dust and condensation. (my brother falsly accused my back brakes of being shot, and my uncle is a mechanic who said otherwise.)
I hope that's all it is.
bulldog
post Oct 12 2008, 10:09 PM
Drives: 2008 Hyundia Accent SE
not sure if it would work for you, but often my mail truck (mailman) will make noises while braking, and "Grab" really bad. i find an area that is clear of any obsticles and back up fairly quick and slam on the brakes. repeat about 3-4 times. usually fixes it for quite awhile.
g3mini
post Oct 13 2008, 06:33 PM
Drives: 2007 Accent
thanks for all of your responses. i will mention it to the tech when i take it in this week for the other problem!
i have another question - i just saw a couple of REALLY BAD chips out of my hood- it's right down to the metal..yeesh...two small spots within an inch of each other.
do you guys think this is something that can be fixed without them repainting the enitre hood - like a spot fix? i just want to be prepared when i get quotes as to what is reasonable...will just putting a bit of paint on it be ok, or are they going to have to do more? i have a feeling because it's down to the metal, that's a little more involved...ugh...
thanks in advance!
This post has been edited by g3mini: Oct 13 2008, 06:37 PM
bloodninja
post Oct 15 2008, 02:06 PM
Expert
here... found it in the OWNERS MANUAL of all things..
QUOTE
BRAKE PAD WEAR WARNING
SOUND
The front disc brake pads have wear
indicators that should make a high-pitched
squealing or scraping noise when new
pads are needed. The sound may come
and go or be heard all the time when the
vehicle is moving. It may also be heard
when the brake pedal is pushed down
firmly. Expensive rotor damage will result
if the worn pads are not replaced. See
your Hyundai dealer immediately.
No New Posts Brakes
Front Rotor replacement
0 gelgin58 21 22nd November 2008 - 12:38 PM
Last post by: gelgin58
No New Posts Brakes
Upgrading Brakes
1 AusDel 106 27th October 2008 - 04:31 PM
Last post by: ken2400
No new Topic has attachmentsBrakes Making Sound And Feeling Bumpy
when hard-stop
36 aung2004 558 30th September 2008 - 07:38 AM
Last post by: bobad
No New Posts Brakes - Pads And Rotors Change
5 anant369 272 26th September 2008 - 02:16 PM
Last post by: anant369
No New Posts Brakes Grinding?
Brakes are grinding on rear driver side
4 rede2sail 441 24th September 2008 - 06:03 PM
Last post by: ddix1026
4th December 2008 - 05:20 PM
