:00000732: Soul!
Amazing that you did not get the Malfunction Indicator Light (mil).
Let's see....2000 Sonata with the early 2.5 liter Delta, 8 years old, probably 120k miles. Bingo! When was your timing belt last changed? You can remove the upper timing cover to inspect with just a 10 mm nut driver. Your car sounds like retarded intake timing maybe by 5-7 degrees. You will need a helper to slowly rotate the engine crankshaft bolt Clockwise while you inspect for broken or missing teeth. If you are at or over 120 k miles, you should replace the timing belt anyway.
If not, you can always change plugs, air filter, and ignition wires.
Byron
