Unnecessary Downshift Using Cruise Control, 2009 Sonata downshifts too much in cruis |
Oct 8 2008, 05:49 PM
Status:
Drives: 2009 Sonata 4cylinder
Our 2009 Sonata Limited 4 cylinder automatic seems to do a lot of downshifting when operated using cruise control. It seems to downshift any time the speed drops about 1 mph so small inclines trigger a downshift from 5th to 4th. We have to switch the transmission to manual mode and lock it in 5th if there are inclines, head winds, etc. The dealer does not seem to think there is anything wrong but all other vehicles I have driven are not nearly so sensitive. Anyone else out there had similar problems or know of any solutions?
Oct 8 2008, 07:08 PM
Status:
Drives: 2009 Sonata 2.4 PZEV
QUOTE(pelden @ Oct 8 2008, 06:49 PM) Our 2009 Sonata Limited 4 cylinder automatic seems to do a lot of downshifting when operated using cruise control. It seems to downshift any time the speed drops about 1 mph so small inclines trigger a downshift from 5th to 4th. We have to switch the transmission to manual mode and lock it in 5th if there are inclines, head winds, etc. The dealer does not seem to think there is anything wrong but all other vehicles I have driven are not nearly so sensitive. Anyone else out there had similar problems or know of any solutions? [right][snapback]195348[/snapback][/right]
Noticed the same thing...the engine is still virgin, with less than 400 miles so I attributed this behavior to that fact, however my 2005 Accord does not behave like this. I'll be happy to hear opinion of others as well.
Oct 10 2008, 05:21 AM
Status:
Drives: 2007 Hyundai Sonata SE 3.3 Powder Pearl White, Born on Sept.22, 2006
I haven't experienced any problems like this. We have taken our Sonata through the Black Hills and the Ozark Mountains and it maintains the speed when using the cruise without downshifting, that I have noticed. But, that can be attributed to the difference between the I4 and the V6. Now that you've go me wondering, maybe this weekend I will go find some roads with lots of hills around here and see what happens. Since gas around here is under 2.80 a gallon, I won't feel bad about driving aimlessly around.
Oct 10 2008, 02:51 PM
VALUED MEMBER
Status:
QUOTE(cmerica @ Oct 10 2008, 02:21 AM) I haven't experienced any problems like this. We have taken our Sonata through the Black Hills and the Ozark Mountains and it maintains the speed when using the cruise without downshifting, that I have noticed. But, that can be attributed to the difference between the I4 and the V6. Now that you've go me wondering, maybe this weekend I will go find some roads with lots of hills around here and see what happens. Since gas around here is under 2.80 a gallon, I won't feel bad about driving aimlessly around. [right][snapback]195590[/snapback][/right]
I have never noticed a downshift while using CC with the 2006 V6. Of course it would downshift going up a hill if needed. You just can't compare the I4 & V6 Sonata. And with Oil at 77.77 a Barrell today and $2.80 a Gallon (I paid $3.79 Yesterday) the smaller engine just doesn't make cents! On a sad note the Stock Market is now in the positive after another 700 point fall today, and when the market rises, Gas prices rise :w00t:
Oct 11 2008, 07:49 AM
Status:
QUOTE(Pelikan @ Oct 11 2008, 07:45 AM) CC shouldn't downshift, it should also be used on flat land NOT on hilly country. Some of you may experience the downshift because with a I4 you don't have enough power to maintain the speed selected. I think it's written in some manual that you shouldn't use CC on hilly country, seems to confuse the computer. [right][snapback]195750[/snapback][/right]
Define hilly country. I drive in MA and I am talking about a highway which is not totally flat, but is not hilly per say. CC should be able to deal with this kind of highway and as I said earlier I compare it to two other Honda Accords that I had (current 2005 and previous 2002), both with 2.4 I4 engines. Neither downshifted as our new 09 Sonata.
Oct 11 2008, 07:56 AM
Status:
Another thing that I noticed (OP, I wonder if you noticed the same thing) - in order to overcome this rapid downshifting I switched to manual, but then I noticed that even when the display shows 5, I can still feel and see through the RPM that it downshifts...not as extreme as from 5 to 4 but still. Is it possible that it downshifts from 5 but keeps the display at 5 because it is in Manual mode? Or maybe this an Overdrive behind the 5th gear??
