Thats the ticket!!! use the warranty, and dont be shy...that "diagnosing tool" also reads any bad codes that WERE stored in it too...sooooooooo.........anyway, usually, that check engine lite refers to the pollution control system, usually bad Oxygen sensors...altho that would be rediculous on a new car...OR it could be the ol loose wire electrical gremlin bad check engine warning lite itself...and although you say you always check the gas cap, and I personally have never heard of that lite coming on while fueling with the engine running which is a no no anyway, i guess its possible...so just drive it and enjoy it, and hopefully itll be another mystery of the sea...(btw, dunno if Hyundais work this way, but other makes actually self-diagnose and correct any problem internally, and after certain number of on/off cycles, the lite goes out on its own..)
