Thanks 273Hypo. I finally found the clip today, and for whatever reason it was between the spacer and the door panel. So my wifes car had a layout of handle/spacer/clip/panel. I ended up taking a piece of steel wire and bending a hook in one end, and then I went fishing and was able to get it off. After fighting with the interior door handle/lock and it's plastic cup, was able to get those out of the way and finally succeeded in getting the panel off. Did what I needed to do and got the panel back on, again a big fight with getting the interior handle assembly to go back through the panel. Thanks for the reply and hopefully will never have to take the panel off again.
