I'd check out if it's the same anti play setup that 98% of the DVD players use. The connect a wire to the emergancy brake and if yoru brake isn't on that it doesn't play DVDs. All you need to do is attach this wire to a constant ground and add in a switch. That way if a cop stops you and tests the DVD it won't play with the emergancy brake off (Good news since it is illegall in most places to have it play otherwise.) But you you wish for it to play, just flick the switch on than off and preto, DVD.
