So here we go 10/09/07 I bought my 2005 tucson with 32k on it. Came with a full 5yr 60k warranty along with a complete inspection of the vehicle. 1 month after owning it the nightmare began. I began to see spots on my driveway, I layed underneath it and found the transfer case was leaking. I work at a shop so i pulled the tsb's and found that their was a tsb on the seal connecting the case to the tranny. I called scheduled an appt and dropped the car off along with the paper work. 7 visits and 40 days all together with out my car later the problem is found that the seal is leaking, each time the work order read something differnet, couldn't find leak or drain plug was leaking. Finally at 44k they decided it was the seal, they pull the case out and see that my other complaint of the car shifting bad is because the tranny has an internal leak. They replace the tranny with a reman tranny and replace the seal along with the axle seals and put it all back together. I pick the car up 12 days later and on the way home had to pull up the e brake to stop from slamming the car in front of me because i later found out they broke the abs reluctor ring and the abs would engage at random times. They fixed it, I figured now the car is done and the problems are over with. Guess again, I take a 4hr trip and find that the transfer case is leaking again and that the car is getting horrible gas mileage and not kicking into high gear and revving around 4 grand at 65mph. I take it back to the shop, they find that 8k later the same seal is leaking. I contact Regional rep Scott Mclarty and by the end of the phone call (i had spoke to him the first time the car had issues and it took 7 visits to fix it) nothing was accomplished out side of him telling me that the warranty states that the problem will be fixed and that nowhere in the warranty does it state they have to look for the cause of the issue, they only have to fix what is wrong with it . He calls me a Fu**ing idiot and tells me I am full of Sh** to think that running a transfer case low for 20k could cause damage to the internals. I told him I wanted his boss to call me because him cursing at me was very un proffesional and that I knew nothing was going to be done . His boss calls me and pretty much tells me the same thing, that I could sell the car if I didn't like it and That they were going to do nothing more for me. So now I am stuck with a pc of garbage HYUNDAI TUCSON. It gets 15-16 mpg tranny is messed up and the front end is falling apart all at 50k. Do not buy one of these cars, The dealer ship is Kerry of florence ky and the regional rep is Scott Mclarty and His boss is Mike Z. I have their numbers if anyone needs them for anything and have already started the paper work with an attorney and contacted BBB. I would like any other help anyone has or suggestions on how to get something done.
