'07 just turned 27,000 no issues related to clutch so far (I think). I am having an issue with my flex pipe rattling (again) dealer has replaced it a couple times as well as the motor mounts and it just started to return again. The motor does flex back and forth more than with the automatic because of the constant on/off thottle when you shift. I do like driving it with the stick and am not the easiest driver. The car gets pretty much full throttle in all gears and normal shifts will be just over 4,000 rpm. For those that don't have the stick, yes the Sonata does have a rev limiter that kicks in just over 6,000 rpm at redline so you don't blow the motor. :innocent: :whistling:
The funny part is that the automatics will also go to redline before shifting if you hold it down enough. My "normal" driving in the automatic yielded about the same shift points as I do manually, just not as much fun.
Besides that all is well. Just don't ask Sort Em about his '09 clutch :whistling: .
I also drove an Elantra (automatic) for a couple weeks while they were trying to fix the rattle. Size, power, comfort theer is NO WAY I'd get an Elantra over a Sonata.
This post has been edited by Sequoiasoon: Oct 3 2008, 10:00 PM
