Hello kev. Look at the oil pipes between the oil cooler behind the front bumper, and the engine. They corrode and break, which will spill all your oil very quickly, especially if you`re doing 70mph on the M62.. This will definitely kill your engine, check the ebay ads re breaking H100s. This is usually the cause. easy to replace though. The is NO manual for this van. At least, none you can get hold of. Only dealers service depts have manuals. I only ever saw one on ebay from a bankrupt garage, it went for £60.00 I use the russek L300 manual which is close enough for most stuff. Loads of L300 parts are used on the H100, inc ball joints, exhaust systems, bearings, engine pumps and seals etc. The engine is basically the same as your 2.5 td L300 Good luck finding a good van.
