 Hyundai-Forums.com > Hyundai Models > Entourage Forum
> Tranmission Fluid Change, Can it be done at home?
kmaren
post Sep 24 2008, 11:34 AM
Drives: Hyundai Entourage 2007 Limited
I was wondering if the transmission fluid could be changed at home. Has anyone tried or looked into it? Any reason to change the gasket on the differential? Do you have to fill the differential seperate? TIA
KMaren
2007 Entourage Limited
sambojoho
post Sep 27 2008, 04:17 PM
Drives: 2002 Hyundai Sonata LX, 2002 Santa Fe LX, 2006 Kia Sedona LX
I changed the ATF in mine. It was very easy. Hyundai gives you a drain plug. I just drained and refilled, plan on doing that every 30k miles or so.
Some advice, the drain plug is directly above the frame. You can't use a socket wrench on it due to this, you will need a standard box end wrench. Also, the fluid will drain on the frame and make a mess, so be prepared!
Clean the magnet on the plug well. Also, there is no filter to replace, and no pan to drop. Be careful when refilling, as you need to do this through the dipstick tube, need to go VERY slow so the air pockets don't belch fluid back at you. I think it took approximately 5.5 quarts to refill mine properly.
I would recommend using only SPIII fluid available only at your Hyundai, Kia, and Mitsubishi dealers.
What differential? If you mean torque converter, then no, there is no separate drain plug.
kmaren
post Sep 29 2008, 03:02 PM
Thank You. The lack of a filter surprises me. Do you plan on dropping the pan at all? Maybe to clean the sludge from the bottom of the pan?
joecamel
post Sep 29 2008, 05:36 PM
Drives: Hyundai Tech
At 60K or so have a trans fluid exchange done with the OEM (SPIII) fluid. This will keep it in the best condition possible. No additives/cleaners needed as the fluid contains plenty.
letsgododge
post Jun 20 2009, 08:57 PM
Drives: 2001 sonata,2007 entourage
QUOTE (joecamel @ Sep 29 2008, 06:36 PM) *
I have a 2001 van Hyuandi,My dad took it in for a clunking noise ,but walked out of there 450 .00$ lighter ,since he supposely drives the vehicle under a severe service the coolant and transmission needed a flush.So he got tooken in by the stealership.
for some odd reason they used a cleaner in the transmission,I cannot figure this one out.
side note ,we change the coolant every 2 yrs and trans fluid every year (give and take a few months)I was thinking I would have to do this near the 100,000 kms mark not 50,000.
hummm.
there is no filter on these models ,if you wanted to get to the screen ,you will have to take the trans out (the pan is actually vertical ) there is a drain plug on the botton ,you should be able to get most of the fluid out (not the converter) ,but its all better than nothing,I would stick with the OEM fluids ,
Jedi-X
post Sep 21 2009, 10:59 PM
Drives: 2007 Hyundai Entourage
QUOTE (sambojoho @ Sep 27 2008, 05:17 PM) *
I was about to change my ATF and was glad to see this post. However, the plug on my 2007 Entourage isn't so much "directly above the frame" (may a little) as blocked by some designer-installed "nubs" (see picture) that can't serve any purpose except to force you to use a specific tool.
Can anyone confirm this is the drain plug before I make a mess of my transmission?
Attached File  2007_Entourage_Transmission_Fluid_Plug.jpg ( 45.31K ) Number of downloads: 25
jsinton
post Sep 21 2009, 11:16 PM
Drives: 1999 Elantra
QUOTE (Jedi-X @ Sep 21 2009, 11:59 PM) *
That's not it.
You want to drain the "pan". It's a flat thing.
sambojoho
post Oct 9 2009, 02:56 AM
Sorry, I just saw this post. Yes, that is the transmission drain plug. There is no bottom "pan" on these transmissions. Those nubs can be cut off, they are aluminum and come off fairly easily. I was able to work around them though.
Volfy
post Oct 9 2009, 10:04 AM
Expert
Drives: 2007 Veracruz Limited
The nubs are there on many late model Hyundai trannies. Some owners just snap them off to get better access. Check the Santa Fe II forum for a recent thread on this same issue.
If you got a wrench that will fit as is, great.
Also, take some newspaper and make a trough under the drain plug the guide the fluid into a drain pan - instead of letting it drip all over the sub frame. I've had to do this for oil & filter changes on many cars. After you are done, just throw aways the newspaper.
No New Posts Change Plastic Engine Cover On A 2001 To 2003 Cover
2 doggie71 38 17th November 2009 - 04:52 PM
Last post by: lovemysantafe
No New Posts Topic has attachmentsChange Entertainment Player
3 khy 109 14th October 2009 - 08:18 AM
Last post by: Robert B.
No New Posts Changed Order From Red To Black :)
6 iMonkey 316 25th September 2009 - 03:59 PM
Last post by: iMonkey
No New Posts Change Head Light
How to change passenger side headlight
2 Notsuitable 272 20th June 2009 - 01:10 PM
Last post by: Notsuitable
No New Posts Change To Syntetic Mobil One 5w30 At Purchase
10 hdsit 331 19th January 2009 - 02:18 PM
Last post by: hdsit
21st November 2009 - 06:14 AM
Privacy Statement
