QUOTE (v33sonata @ Nov 10 2008, 07:16 PM)
This is true. I have to wait for now. Sorry [it] so long in getting back to you guys.
The motors are the same weight. It's [basically] the same motor just [with a] different bore and stroke!
If ANY of you find a S/C that is made will fit on my car, let me know. I will buy it tomorrow.
(IMG:
style_emoticons/default/grin.gif)
Please,
if you find a blower, DO NOT INSTALL IT!
Normal pistons
cannot and
will not stand the added pressures, and you will destroy your 3.3.
Even forged pistons sometimes will self destruct. All it takes is for
the motor to run lean for a nano-second and there she blows!
You might be able to 'get away with' up to only five pounds boast for a short while, but
it won't be long before your pistons with self-destruct and that can be very expensive.
Stick with
your original idea of going with the factory 3.8L. Your lighter Sonata should fly!
Who will you get or do you know of
anyone that can 'tune' your computer
to make the necessary 'corrections' to help pervent such problems?
I have much experience with trying to simply slap a supercharger on my new at the time Impala SS.
I didn't get 5K miles before I blew a piston. After going to a 383 cu in motor, I lost three more. (IMG:
style_emoticons/default/crying.gif)
Finally set the Procharger aside and wound up with a 385 inch motor with 11 to 1 C/R and an
LT4 hot cam, and the heavy SS would run in the mid 13's at 104 MPH, but then
the trannies could not take that much power, and so forth. F E when to H...;
Dependability was less than poor and, well, I hope you get the general idea.
HTHs (IMG:
style_emoticons/default/amen.gif)
Delfin
